Thanks for the "Komenda-Commendation" Jack! but I'm just a hobbiest hack with a wire-welder and a lot of cardboard to make templates with.
Thanks again! Justin
2/29/14
Left side inner flange repair in steel.
basic part trimmed out of steel and in for an initial fitment.
Had to pie-cut two reliefs into the face so the mount flange would hug the embossment at the top as it did before. Back filling the spaces here.
New piece fully welded and dressed here. You can clearly see how the inner flange in no way runs parallel with the outer flange.
Very similar to the way it came from the factory but a bit beefier with that heavier gauge square stock in there...
Mounted again to make sure it still fit like it was supposed to.
Couldn't be happier, fits just like its paper cousin.
Anchor plate flange will be eventually plug-welded onto this new inner wall as it was done originally.
Will cap the bottom up tomorrow and begin the right side inner flange.
Thanks for looking! Justin
2/29/14
