Thanks Roy! Yes, Leaving your car as is and just enjoying it is a very wise decision indeed, I envy you.
6/!8/18
Prepping the new jack spur
Referred to my factory manual for the exact placement of the spur once again.
Here is 415MM from the center of the rearward spring plate bolt. Centered right over the bulkhead assembly as it should.
Like the coupster before the new jack spurs need some detail trimming to better match an original example.
Start with excess off the snout. Trimmed back right to the shoulder of the weld.
Quick filing to clean up the edges.
Immediate authenticity improvement.
Upper and lower flange shaping next.
Thanks for stopping by!
6/!8/18
Its critical to have a reference car and or parts otherwise how would you ever know.
Peeling it back off next to prep it for final welding.
