    commented on 's reply
    Thanks Roy! Substructure is basically holding the shape of that skin. I'll be nipping and tucking the door frame as I always do to get it all to match. Justin
  • roy mawbey
    replied
    Justin that door closure gap is going to look so good. I will be interested to see how you will remove that very minor 'bow ' in the door skin. Shrink ???
    Leave a comment:
    replied
    Splash pan repair section complete:
    Click image for larger version  Name:	IMG_2085.jpg Views:	0 Size:	189.1 KB ID:	115228 Rocker mocked up one more time before I commit to fully stitching that new section on.
    Click image for larger version  Name:	IMG_2086.jpg Views:	0 Size:	164.7 KB ID:	115229 I've got my 3MM gap and the best average match to the edge of the door. The door has a slight bow to its profile and that will need to be softened but these adjustments are now minor corrections.
    Click image for larger version  Name:	IMG_2087.jpg Views:	0 Size:	184.3 KB ID:	115230 With the rocker in the sweet spot I simultaneously have the tight uniform fit against the back side of the rocker that I was shooting for. ready to stitch this up.
    Click image for larger version  Name:	IMG_2090.jpg Views:	3 Size:	207.9 KB ID:	115231 Lower stitching as well as the corner welding and lateral flange repairs complete. Excess to the inside lap joint trimmed and shaped to the original sweeping profile.
    Click image for larger version  Name:	IMG_2092.jpg Views:	3 Size:	183.5 KB ID:	115232 Another confirmation fit. All set and onto the next issue.
    Thanks for looking.
    Leave a comment:
    Thank you Roy. I remember seeing your old photos of that repair and I know you can appreciate what's on here.
  • roy mawbey
    replied
    A nice repair Justin. That was one area just the same sort of size I had to repair on the r/side of my car Justin about 47 years ago !!
    Leave a comment:
    replied
    New splash pan repair section:
    Click image for larger version  Name:	IMG_2074.jpg Views:	0 Size:	198.6 KB ID:	115220 Onto metal. Basic shape with lateral and lower flanges installed.
    Click image for larger version  Name:	IMG_2073.jpg Views:	0 Size:	173.6 KB ID:	115221 Final placement of the new repair section is dependent on a tight fit against the inside of the rocker panel and whare it is positioning the rocker in relation to the edge of the door.
    Click image for larger version  Name:	IMG_2081.jpg Views:	0 Size:	173.4 KB ID:	115222 Bottom edge of the door has a bow that will need to be softened but this is my best average fit with a 3mm gap.
    Click image for larger version  Name:	IMG_2082.jpg Views:	0 Size:	230.3 KB ID:	115223 Dialed in close enough to commit to a final cut line. Ready to begin joining these two together.
    Click image for larger version  Name:	IMG_2084.jpg Views:	0 Size:	183.8 KB ID:	115224 Tacked and on for another test fit before I fully stitch these two together. Put a step in the lateral flange to accommodate the lap joint between the fender and the rocker so I could get this flange to butt up just a little closer.
    Leave a comment:
    replied
    Lower Splash pan repair:
    Click image for larger version  Name:	IMG_2068.jpg Views:	0 Size:	176.9 KB ID:	115214 Begin fitting the new rocker skin to the bottom of the newly adjusted door so I can dial in the final shape and flange position of the eventual lower patch repair section it will mount directly onto.
    Click image for larger version  Name:	IMG_2067.jpg Views:	0 Size:	231.7 KB ID:	115215 To get the rocker skin level with the bottom edge of the door creates a big gap with the mounting flange with the remains of the old wall.
    Click image for larger version  Name:	IMG_2070.jpg Views:	3 Size:	218.0 KB ID:	115216 I cut the old lower section free and moved it out a few MM's where it now needs to be.
    Click image for larger version  Name:	IMG_2069.jpg Views:	3 Size:	189.2 KB ID:	115217 That adjustment gives me the best average fit all around. Once this section was determined to be short a final three piece repair section down here was looking less likely.
    Click image for larger version  Name:	IMG_2071.jpg Views:	3 Size:	191.4 KB ID:	115218 Began developing my paper template for a clean and tight one piece repair panel.
    Thanks for looking.
    Leave a comment:
    replied
    Left door set onto building the body around it.
    Click image for larger version  Name:	IMG_2062.jpg Views:	0 Size:	146.9 KB ID:	115208 Basic 3MM gap with the top edge of the door level with the bottom of the quarter window opening...finally.
    Click image for larger version  Name:	IMG_2060.jpg Views:	0 Size:	180.9 KB ID:	115209 Improved but still a touch proud up top with the belt line of the door (door handle area) even. Frustrating but I'll get it all lined up before its over.
    Click image for larger version  Name:	IMG_2063.jpg Views:	0 Size:	153.2 KB ID:	115210 Bottom tucks a little too quick as well but again these will all be dealt with as the progress continues.
    Click image for larger version  Name:	IMG_2064.jpg Views:	0 Size:	174.5 KB ID:	115211 Now that the door is in its final adjusted position I can begin repairing and remounting the splash pan.
    Click image for larger version  Name:	IMG_2066.jpg Views:	0 Size:	202.1 KB ID:	115212 Door had to be in final position so I could reset both this mounting flanges height and distance to the leading edge of the door.
    Thanks for looking.
    Leave a comment:
    Hi Roy, I could get the rear gap I was after if I lowered the back of the door but I'd lose the line along the top edge and then Vise vera. It just wouldn't give me both without getting into the hinge mounts again. All par for the course my friend as usual. Thanks again!
  • roy mawbey
    replied
    Justin well I think I would have had a 'nightmare' with this last exercise of yours. So to get that sorted as I can see in the last photos you took, you must be a happy guy for sure! By yourself this car has presented so many hard to resolve problems but the standard of repair, has looked so good with everything you have been working on. You deserve a medal and I hope the owner agrees this has been a real eye opener of a 356 body restoration.
    Leave a comment:
    replied
    Click image for larger version  Name:	IMG_1987.jpg Views:	0 Size:	161.6 KB ID:	115199 The rest of the door frames' gap in the roof opening runs about the same width. Centered in there as best as I could hope for.
    Click image for larger version  Name:	IMG_2055.jpg Views:	3 Size:	216.4 KB ID:	115201 With that confirmation Both the upper and lower hinge mounts were all welded up. Upper hinge half cleaned and bolted on for the last time.
    Click image for larger version  Name:	IMG_2056.jpg Views:	3 Size:	199.8 KB ID:	115203 Lower hinge mount welding also completed.
    Click image for larger version  Name:	IMG_2057.jpg Views:	3 Size:	206.5 KB ID:	115202 I added the lower extension tie in to the mount first so I could bolt the hinge half on for good. I'll weld it to the threshold once I have the final height of the rocker assembly dialed in.
ID:	115204 Lower hinge half cleaned, shimmed and bolted in for the final time. Pulling the pins for door removal makes life so much simpler. To disturb these bolts again at a later date would be a huge PIA. It takes the use of a floor jack to raise the door up where it needs to be while you tighten the bolts. A big pain, especially if you're on your own. Anyway, right door all set into final position.
    Leave a comment:
    replied
    Finishing up the hinge mounts:
    Click image for larger version  Name:	IMG_1980.jpg Views:	0 Size:	171.5 KB ID:	115193 Fastforward to now and finally tying up this loose end. Its all changed so I was also playing around with various shim thicknesses as I went.
    Click image for larger version  Name:	IMG_1978.jpg Views:	0 Size:	173.5 KB ID:	115194 After a bit of trial, error and slight adjustments through both the upper and lower hinges I finally had my best adjusted position.
    Click image for larger version  Name:	IMG_1982.jpg Views:	0 Size:	221.7 KB ID:	115195 As it went I had some height transfer issues with the edge of the cowl to the door. I melted the solder back to expose what was really under the lead. Left very raw in through here with a lot of solder used to smooth it all out.
ID:	115196 Finally had the top edge of the door aligned to continue into the quarter window opening with a good basic 3mm gap.
ID:	115197 Gap between the door frame and the B-pillar at a manageable distance.
    Leave a comment:
    replied
    Hinge work:
    Click image for larger version  Name:	IMG_7122.jpg Views:	0 Size:	110.9 KB ID:	115190 Elongated the holes to get the door to move back further.
    Click image for larger version  Name:	IMG_7121.jpg Views:	0 Size:	139.2 KB ID:	115191 Next was shaving the rearward shoulders off of the plates to take full advantage of the elongated holes before these bottomed out against the inside of housings.
    Click image for larger version  Name:	IMG_7209.jpg Views:	0 Size:	92.5 KB ID:	115187 next issue I noticed was that the top mount had bowed shape in the mounting flange.
    Click image for larger version  Name:	IMG_7208.jpg Views:	0 Size:	110.5 KB ID:	115188 Tried drawing it back out but the bow would come right back once the pressure was released.
    Click image for larger version  Name:	IMG_7210.jpg Views:	0 Size:	106.4 KB ID:	115189 That bowed shape finally gave up once the old gas weld was cut through. It was a promising start but left this and went back to chassis repairs. Now I was back on finishing this door fitment issue up. That up next.
    Leave a comment:
    replied
    Right door fitment issues from the start:
    Click image for larger version  Name:	IMG_7157.jpg Views:	0 Size:	94.3 KB ID:	115181 Just like the left door this right side insisted on mounting a touch too far forward. Once the top of the door was set even with quarter window opening this 5mm+ rear door gap was what I was left with. I could get it to close up but meant lowering the back edge of the door out of alignment with quarter window opening.
    Click image for larger version  Name:	IMG_7158.jpg Views:	0 Size:	106.9 KB ID:	115182 I thought about building the edge of the striker to close up this door gap but after mocking up the window frame that wasn't an option. The frame is not moving and gap with the B-pillar is almost 10mm. Completely unacceptable fit.
    Click image for larger version  Name:	IMG_7160.jpg Views:	0 Size:	99.9 KB ID:	115183 Before I removed the front fender it was confirmed that this door just needs to come back a few MM's. I attribute this non existent gap as old front end collision damage but it does not account for the huge rear gap.
    Click image for larger version  Name:	IMG_7211.jpg Views:	0 Size:	117.4 KB ID:	115184 While all that was going on I also had profile issues with the edge of the door. Top stands out too proud while its even at the mid-line/ door handle area.
    Click image for larger version  Name:	IMG_7213.jpg Views:	0 Size:	98.3 KB ID:	115185 Then tapers too quickly as it makes its way down. My plan was to correct as much of this as I could through the hinge assemblies.
    Leave a comment:
    replied
    Old rocker skin removal:
    Click image for larger version  Name:	IMG_1927.jpg Views:	0 Size:	201.2 KB ID:	115176 Usual process of drilling and breaking the old spot welds. During the forward removal I spotted some old accident damage I had overlooked previously. The drain tray up here is still a bit smashed and bowed in narrower than it should be. It will be easy to relax back out once the skin is removed
    Click image for larger version  Name:	IMG_1928.jpg Views:	0 Size:	233.7 KB ID:	115177 Just a few more stubborn welds remain.
    Click image for larger version  Name:	IMG_1929.jpg Views:	0 Size:	200.1 KB ID:	115178 New skin on for a quick initial mock up. Looking better already.
    Click image for larger version  Name:	IMG_1970.jpg Views:	0 Size:	206.3 KB ID:	115179 Before I can begin installing anything, this door has to be set in its final adjusted latched and hinged position so I can build around that. Its been giving me some contour issues with the rear quarter panel from the beginning. Will be posting that up next.
    Leave a comment:
