John, you may have this thought-out, but I'll say it anyway....don't fasten the front half until the rear half is jockey'd into place, as well.
Only Porsche could get away with a pre-welded whole floor as that and the rear bulkhead were where the chassis began on the jig.
I got a whole NOS pan from Dick Milstead to install in his Cabriolet and had to cut a bit off the front and weld it together again after it was in.
If the inner longitudinals are installed and complete, the "shoehorn" of the floor is difficult if not impossible if it's complete or one half is welded to the tunnel. For one thing, it's easier to get the slight 'V' one half at a time and secure those when the transverse upper/lower 'tube' mid brace is located in the notch in the tunnel's both mid-sides. Cleco or screw before welding and begin at the mid tunnel, both sides and then left and right mid-edge and lace it from there, holding the floor up under the center fore and aft as the edges can be pressed down by the drill or screw gun as you cris-cross your way from middle to front and back sequentially.....but you already had that down, right?
I thought so.
Great workmanship!
"How long can that take?" "Why does it cost so much?"
I thought so.
Great workmanship!
I've not seen that before, but it definitely looks like a Karmann plug in the floor of the battery box. Some people speculated these holes were there to help drain the primer out while others have said it's for a jig. But in the battery box? It is a low spot so maybe the paint draining does make sense. Just one more thing to add to the list. Tom: you too? Great picture and thanks for sharing it!
