I contacted Zims and Restoration Design regarding there front quarter patch.  Zims does not have the double flange and Resto Designs does.  I cut loose the bottom of the quarter and it moved quite a bit.  There were stresses in that panel from prior accident damage.  Almost looks like the rear door gap took a direct hit somehow, as there was damage along the top half of the door edge and all along the first 5 or 6 inches of the quarter.  Spent some time removing more lead from the quarter and tried to reshape it.  Decided to order the Resto Design panel, as this is a similar situation that Justin had on his coupe except a much smaller area.  Back on page 8 or 9 of this thread where I showed some string checks it showed both the upper door and quarter were low from the handle up.  I was able to correct the door with a dolly on the inner flange and whacking it with a rubber mallet.  This moved the low areas back to flush.  There is still some lead at the top of the door, and it may remain.  Ground off the rest of the quarter flange from the lower lock post.  While waiting for the quarter repair panel I will do some cleanup work on the lower lock post from and earlier repair and go back to working on the rocker.
You can see in this pic how the quarter moved when freed up.
 Interested in seeing how the RD part you've ordered shapes out against the door. Keep up the great work! Justin
						 Phil did you trim a section off of your striker plate or is it factory?
