Justin,
Yes, my car is T1 but has been repaired with a T2 wall. I can either use that panel or a Simonsen that i believe will be identical. What i would like to know is the conversion needed. I still do not fully understand what you mean that it won't fit. If both panels are identical in length (so the trunk is the same) both should fit although one should have a bigger battery box and the other bigger sides but that doesn't seem what you mention, that's why i'm puzzled.....
Ignacio
Ignacio
