While waiting for my headlight seals I have been investigating original headlights. Interesting discussion on the R:
http://forum.porsche356registry.org/viewtopic.php?f=13&t=45788&hilit=headlight&start=15
and I read what was is Brett Johnsons' book. John, assume most of this applies to your T6B also.
Even though the my units are not original(as I recall PO said he had them somewhere) they are 5 & 7 o'clock adjusters which seems to be what was used in 63. They have park light bulbs, which I have removed, and plan to make some 1" square covers per above R post. One is pretty pitted and has been painted over. Have found another unit with original block off piece still in it that looks pretty good and may buy.
Also, discovered cold welds on drivers side fog light bracket so removed it and rewelded with welder on higher setting for 16ga. rather than 20ga. and that seemed to do the trick. The bracket is much thicker than the fender and I used my typical setting. Glad I caught it now.
Also found a decent condition and priced wheel with 62 date code as Foam Car never had a spare. One advantage of a slow restoration is you can wait until you find a reasonably priced part.
and see if they can help you and all of us by providing parts of parts. They sell unassembled rockers to me if they have loose pieces. Same price, less work for them and better for me.
