    commented on 's reply
    Thanks Roy! Good eye, Looks like I mocked up two Right sides. Just have to flip it over and move the thread plate to the other side to create a left side.
  • roy mawbey
    replied
    Well done Justin always a step nearer!! Good job with the new bumper irons great to see them fit so well in th e slots. Does one of these need to be turned upside down through 180 degrees?
    Leave a comment:
    replied
    Right side repair patch installed.
ID:	114882 Fine tuning the shape. Excess cut away and tack-welding together.
ID:	114883 New section just about stitched in.
ID:	114884 All stitched in.
ID:	114885 A little fine finishing and welding yet but the heavy lifting is done on this one.
ID:	114886 Toyed with installing it in for good now but It will have wait until the fender is all welded in. I need clear access to work the back side of the weld joint once the new nose and fenders are finally stitched together. Repeat the left side bucket repairs here shortly.
    Leave a comment:
    replied
    Rust repairs on Right side bucket:
ID:	114876 Tried to stay conservative by drilling out only the rust breached areas but as I began trying to weld in the new patches to plug these holes the shoulders kept blowing through. While it hadn't rusted through the inner surfaces where just too pitted and thin. I had no choice but to cut past these compromised areas.
ID:	114877 Began paper template for a new section.
ID:	114878 Not a big section but a bit of complicated domed shape.
ID:	114879 Then onto steel. Relief cut in sections to allow the needed shape to develop.
ID:	114880 Only a small portion of this donor will be used once its all over.
    Leave a comment:
    replied
    Click image for larger version  Name:	IMG_1514.jpg Views:	10 Size:	192.4 KB ID:	114870 Onto the next deal...
    Click image for larger version  Name:	IMG_1405.jpg Views:	0 Size:	197.5 KB ID:	114871 Begin headlight bucket repairs. Some rust at the bases and old residual accident damage to address. Especially along that lateral leading edge where it had been beaten on by the body shop so many years ago.
    Click image for larger version  Name:	IMG_1407.jpg Views:	0 Size:	198.3 KB ID:	114872 Original trim ring installed to dial in the correct shape around the lip where has some damage had occurred.
    Click image for larger version  Name:	IMG_1409.jpg Views:	0 Size:	201.4 KB ID:	114873
    There was an attempt to beat out this lateral area while still installed in the car but as you can see it still remained too flat.
    Click image for larger version  Name:	IMG_1414.jpg Views:	0 Size:	206.4 KB ID:	114874 While hammering progressed on the left , the right bucket was acid bathed to clean up the residual rust along the mounting surface.
    Leave a comment:
    replied
    New bracket mock up.
ID:	114864 Brand new set. Will need lots of tweaking once the actual bumper fitment starts I'm sure.
ID:	114865 Brackets drawn tight against the mount and no clearance issues with the skin.
ID:	114866 Ample room for any adjustments but most importantly the holes look like it should.
ID:	114867 Could have been cut narrower for sure at the insides...
ID:	114868 But this was how it was done.
    Leave a comment:
    replied
    Opening the bumper bracket holes:
    Click image for larger version  Name:	IMG_1431.jpg Views:	0 Size:	218.6 KB ID:	114858 The noses location is set , now was the time to go ahead and cut in the bracket openings. The inner diameter of the bracket mount's footprint was traced to the inside of the wall to ensure final opening's location would end up exactly where it needs to be.
    Click image for larger version  Name:	IMG_1498.jpg Views:	0 Size:	235.4 KB ID:	114859 Once those foot prints where traced the nose was dismounted to mark out the final opening size and then cutting. Final cut lines have been established here and are based on my original examples.
ID:	114860 Openings cut open and nose remounted for a confirmation. Bumper irons should clear fine.
ID:	114861 By the way the final lateral cuts where not centered with the original markings. I had them favor to the outside because once the mounting bolts are drawn up tight the assembly moves towards the outer shoulders.
ID:	114862 Stuffed the bracket mounts with paint sticks and no signs of interference with the skin.
    Leave a comment:
    replied
    Click image for larger version  Name:	IMG_1453.jpg Views:	0 Size:	215.8 KB ID:	114854 Harvested the original clipping strip for additional hole placement confirmation.
    Click image for larger version  Name:	IMG_1478.jpg Views:	0 Size:	211.8 KB ID:	114856 Confirmed. Holes in just about the right spot and slightly lower than the center hole.
    Click image for larger version  Name:	IMG_1477.jpg Views:	0 Size:	232.1 KB ID:	114855 Again, this easily overlooked detail gives a nice victorious banner type attitude to the emblem. Now back to messaging that poor roughed up trough section.
    Leave a comment:
    replied
    Emblem placement trial and error.
    Click image for larger version  Name:	IMG_1469.jpg Views:	0 Size:	166.9 KB ID:	114848 Jumped the gun and drilled the emblem holes at center nose. Then I got around to digging out my original emblems only to discover the center pin is off center of the center letter by about 5MM.
    Click image for larger version  Name:	IMG_1471.jpg Views:	0 Size:	190.6 KB ID:	114849
    This discrepancy might well have slipped past detection but I couldn't look at it from here on in as it would have drove me nuts. Correction holes in red moved off center that 5mm to compensate for this pin placement.
    Click image for larger version  Name:	IMG_1468.jpg Views:	0 Size:	175.4 KB ID:	114850 Emblem now mounts fully centered on the nose.
    Click image for larger version  Name:	IMG_1467.jpg Views:	0 Size:	202.3 KB ID:	114851 Cellette bench used once again as a sight mark to ensure the emblem sits level.
    Click image for larger version  Name:	IMG_1472.jpg Views:	0 Size:	218.1 KB ID:	114852 Initial holes back filled and dressed smooth. Emblem set. The lateral pair of holes are drilled slightly lower than the center putting a slight arc in the emblems overall profile as it wraps around the nose. As I became more aware of this detail the emblem does take on a banner shape which gives it some flair. Without an original reference I would have just laid it straight across the nose.
    Leave a comment:
    Thank you Roy, but actually by this point I still wasn't out of the woods with that hood to nose transition. It would fight little more before I finally put it to bed. That up here shortly. Thanks again! Justin
  • roy mawbey
    replied
    Justin, well done indeed you must be happy about that correction. That job would have been beyond most peoples ability and once lead skimmed will turn out just fine I think. Your experiences gained even down to the template for the badge tell me you never give up when many would!!
    Leave a comment:
    replied
ID:	114825 All stitched with welds dressed down. Still have some stitching and finishing along the tough but I wanted to get the welding with the nose completed first.
ID:	114826 Most of this run all welded back together with only the left side run remaining. Far from perfect but again only skim coat of lead needed to finish out the final gap and contour shapes of the end of the hood.
ID:	114827 Got tired of welding and grinding so I took a break to locate and drill the front emblem holes. Once again an original reference saves the day.
ID:	114828 Basic template off of it.
ID:	114829 Then transferred over onto the new nose.
    Leave a comment:
    replied
    center correction patch.
ID:	114819 Basic shape and contour I was after. Small lip was left to make up for the slight distance outward it needed to carry on the line of the hood.
ID:	114820 Final trim and new section tacked in. A relief cut was added below it as there was a touch too much crown and I needed to gather up the metal along here.
ID:	114821 A tack was added with each slight adjustment as it went in. All but set here and ready to just lay down some final seam welds.
ID:	114822 With the edge of the hood relaxed outward the new section is about 90% there. I'll take it in the rest of the way with skim coat of lead.
ID:	114823 General profile is now well within striking distance. Again just a smear of lead will correct the shortfalls.
    Leave a comment:
    Hi Roy, Its getting there. Sometimes I don't see it all even being right in front of it but eventually the flaws come into focus at least i hope that it does and that I catch them before its too late. Thanks again!
  • roy mawbey
    replied
    Justin I can see it looks better even without any work yet, the fresh piece of steel will work . Yes two wrongs do not make a right. You have found out the hard way. Its true also, photo's can disguise a lot and you have to see it in front of you ,to be sure if the action to take. You cannot always see as a bystander like me, the problems you have been faced with. I just saw the lid that was miles out from the nose suddenly coming into spec with all that work. What I did not notice were points you raised about the flatness aspect which proves you have to be in front of it, or a perfect example you can copy to see the error's you make.
    Keep at it and keep smiling !
    Leave a comment:
