Dedicated build thread for the new hot rod Polopolus 911 4-cylinder engine for my motorless Carrera coupe restoration.
To keep entries of this particular aspect of the build from getting lost in the shuffle with the body details I thought it best to begin a separate thread post. Will share all information, build details, plans and current progress. This may take a little while; being a regular guy I have to do this a dime at a time...
My brand new Polopolus casted engine block the day I got it home. What a beautiful work of art with so much potential!
No longer a cut and re-welded factory 911 engine block but a brand spanking new casting. Dean says this was almost 20 years in its development to find the right foundry and the metallurgists to create these pieces.
As of this entry a Basic kit from Dean which includes this block, a New crankshaft, a pair of cams and a shortend pair of 911 cam towers is just under 20K. It is then up to the owner to procure the stock 911 components to complete the engine. A turnkey motor from Dean of course goes up from there and also depends on how radical you wish to build it.
This engine:
I am of the opinion that there is no replacement for displacement so I told Dean I wanted to push the CC's up as far as we could while keeping good reliability. I want a "stump-puller" motor that makes its move at the lower RPM ranges.(that's were I like to drive) I do not like high-winding engines that make their peak HP above 5K RPM. Although I know they can operate fine in that range I personally don't like hanging out there. So for my taste and enjoyment I need this engine to make lots of HP under 5K RPM.
Displacement:
The Pistons and cylinders I bought were an incomplete set of 5 (perfect for my application) 102mm Mahle factory racing 3.8 RSR units in good used condition.
Big recessed pockets for some heavy-duty valves.
In keeping with my large displacement desire, this motor is going to come out at just under 2.7 liters These 102MM units along with an 80mm stroke crankshaft.
Cylinders show no wear or scoring. Not the Teflon coated piston skirts. I just love race parts! More later.. Thanks for reading this! Justin
This engine:
Displacement:
Horrible news!
What can I say; its old used racing equipment that has had a hard life. Buyer beware. I checked with several Porsche vendors about a new set. I was getting quotes in the 750.00-1,000.00 range. PER VALVE!!! Fortunately, I found a manufacturer that could duplicate them for me at a much more realistic price. Still not cheap but managable.
A week later I get an email saying that the valve springs were now coil binding with the cam profile we chose and Walt stated that we needed to gain 2MM for proper clearance. He Could not mill the heads for this distance due to the radical porting; Not enough meat there.
That is a great photo of your car and looks like it should be on the cover of a catalog! It sounds like you had an amazing trip; Any more photos?? Thanks for your reply! Justin
