A few updates. Roll bar shape now complete nicely hugs the body shape by 3/4” Off to get media blasted then epoxy coated and sanded before paint. Wire loom is in and tucked
in place in the rear. Black Mercedes insulation glued under transmission tunnel then two coats of black rustoleum. Rear firewall all tucked in With noise proofing (a few layers to fill in voids between ribs.
Canuck 1960B T5 Coupe Resto
Installed refurbished numbers matching transmission. https://www.facebook.com/share/r/18d...ibextid=wwXIfr1960 356B T5 - under major resurrection.
Installed 6volt electric fuel pump and finishing up frunk sanding and prep for paint.
Last edited by Scott B; 03-28-2026, 02:35 AM.1960 356B T5 - under major resurrection.
My friend Dave was able to source a rare NOS hirschmann centre mount antenna. Temporary window installed along with the windshield wiper mechanism to ensure that the mounting hole to be drilled and bottom mounting bolt wouldn’t interfere. Also wanted to ensure the wipers would have clearance. The antenna is then angled upwards to the roof close to parallel to the windshield. On the roof a holding clip will also be mounted to secure the top of the antenna. Love the look of this rare accessory. Here is a pic of Mr porsche with his early VW and a centre mount antenna.​1960 356B T5 - under major resurrection.
Happy with where it is positioned.1960 356B T5 - under major resurrection.
