  • Justin, Hoo-ray and well done great result. "When you first started on this car some years ago now, to do just the bodywork is that still the case? Have you not become attached to it after all effort? I suppose its the effort I have made over the past 56 years or so, that makes me keep mine. My middle son in his mid fifties, has been an invaluable help to me on some jobs on my 356 over recent years, as you can't always achieve in your eighties, jobs you did easily in your 50's.!!
      Thank you Roy! The bodywork and final paint will be handled by a local shop in his hometown. My final mission will be to rough in the body to a level that any competent bodyshop can finish it out correctly. Actually its quite the opposite, I am very anxious to get his car back to him. He has been incredibly patient and understanding so I really want to get this old shell back to him as soon as I can wrap it up. Thanks again! Justin
  • Ready to come off the Cellette Bench for the final phase.
    Click image for larger version  Name:	a59crp_3316.jpg Views:	0 Size:	187.1 KB ID:	117053 Gone as far could with it mounted to this frame table. To finish up the loose end chassis work it had to go back on the rotisserie but before I could do that the rear bumper work had to be completed first as the rotisserie attaches to the bumper mounts. Dismounting it was bit dicey at times as this was a one man operation but I just took it very slowly.
    Click image for larger version  Name:	a59crp_3317.jpg Views:	3 Size:	206.7 KB ID:	117054 Cellete bench out of the way and ready to mount it on its dolly so it can go back inside.
    Click image for larger version  Name:	IMG_3321.jpg Views:	3 Size:	214.7 KB ID:	117055 Safely remounted back on the rotisserie.
    Click image for larger version  Name:	IMG_3322.jpg Views:	3 Size:	195.2 KB ID:	117056 This is dolly it was mounted to when it showed up. It was built to the car so now in a relaxed state the misaligned mounting saddle bares witness as to where the beam was before it was pulled back out to factory spec on the Cellette. Not end the world and probably could have been compensated for but its now corrected and the chassis blessed on the bench.
    Click image for larger version  Name:	IMG_3323.jpg Views:	3 Size:	242.5 KB ID:	117057 Ready to begin tying up the loose ends I had no clear access to mounted on the frame table. Finishing out the plug welds long the lateral gussets, the rear wall of the battery box and then onto mounting the diagonal brace. All that up next.
    Thanks for looking.
    • Lateral gusset loose ends.
      Click image for larger version  Name:	IMG_3324.jpg Views:	0 Size:	253.6 KB ID:	117059 Frame table certainly had its roll to play but no way to get a clear shot at these areas. A rotisserie is the only way to go
      Click image for larger version  Name:	IMG_3325.jpg Views:	0 Size:	201.9 KB ID:	117060 Starting with the gusset plug welds along with those three plug weld holes along the bottom flap of the new closing wall. The factory only had three spots securing that run. Begin test fitting the new diagonal member as well.
      Click image for larger version  Name:	IMG_3326.jpg Views:	3 Size:	223.3 KB ID:	117061 Plug welding complete and in process of dressing them smoothly here.
      Click image for larger version  Name:	IMG_3351.jpg Views:	0 Size:	249.0 KB ID:	117064
      Then it was onto adding the seam weld detail along the leading edge at the front bulkhead as found originally.
      Click image for larger version  Name:	IMG_3352.jpg Views:	0 Size:	243.9 KB ID:	117063 And finally seaming up the back leading edge. I would have bridged these two edges together solid with weld but that is not how they did it. Lateral gusset installation complete.
      Thanks for looking.
      • Battery box loose ends:
        Click image for larger version  Name:	IMG_3345.jpg Views:	0 Size:	224.5 KB ID:	117066 Another unreachable area with it mounted to the cellette bench. Had to install more set screws than usual to hold these panels tight for welding
        as no clamp is big enough to reach this flange.
        Click image for larger version  Name:	IMG_3346.jpg Views:	0 Size:	219.8 KB ID:	117067 Center recess wall all welded up with gas welds added along the four corners as my original reference piece shows.
        Click image for larger version  Name:	IMG_3348.jpg Views:	14 Size:	194.5 KB ID:	117069 Same process, leap frogging each plug weld with lots of set screw to ensure a tight fit.
        Click image for larger version  Name:	IMG_3358.jpg Views:	14 Size:	259.2 KB ID:	117070 Then down the left and right sides to add in the gas welds at the corners and the tips of the fender braces as found originally.
        Click image for larger version  Name:	IMG_3334.jpg Views:	0 Size:	175.0 KB ID:	117077
        Carefully cutting through the old gas welds to remove the remains of the original diagonal brace. There is a stepped shoulder that the braces ends seat into so I had to make sure I didn't cut too deep.
        Thanks for looking.
        • Initial loose ends completed
          Click image for larger version  Name:	IMG_3359.jpg Views:	0 Size:	233.4 KB ID:	117072 Plug welds dressed smooth then followed up with the panel spotter for the finishing detail.
          Click image for larger version  Name:	IMG_3360.jpg Views:	0 Size:	224.7 KB ID:	117073 Panel spotter follow up along the back battery box wall flange.
          Click image for larger version  Name:	IMG_3364.jpg Views:	0 Size:	225.1 KB ID:	117074 Got the recessed mounting flanges cleaned of the remains of old diagonal brace in preparation for mounting the new one.
          Click image for larger version  Name:	IMG_3365.jpg Views:	0 Size:	216.5 KB ID:	117075 Began prepping these finished surfaces for a sealer coat.
          Click image for larger version  Name:	IMG_3366.jpg Views:	0 Size:	195.3 KB ID:	117076 Initial sealer applied and now onto prepping for the diagonal brace installation.
          Thanks for looking.
