    commented on 's reply
    Thanks Roy! Now was the moment to address these ticking time bombs while we were this far into it. This lower leading edge of the hood will always be exposed to moisture either from being washed, or driven in the occasional rain shower. It will pool along the trunk seal and go to work on that lapped underside leading edge or some water could also get by the hood handle seal allowing it in behind through the stud hole as it did initially. Now, no matter happens, all that old rust is gone and no longer growing. As I said earlier, we'll all be long gone before it becomes a problem again. See all the fun you're missing having a rust free hood? Thanks again! Justin
  • roy mawbey
    replied
    Justin so sensible of you and your mate to decide to do that! As you say a few years and it would have showed up. Again I have to say it thank goodness mine is rust free. Never seen that repqir noted and made safe as you have done on any site.
    Well done,
    Leave a comment:
    replied
    Click image for larger version  Name:	IMG_0602.jpg Views:	0 Size:	234.2 KB ID:	114386 Welded up the breaches that revealed themselves after cleaning.
    Click image for larger version  Name:	IMG_0608.jpg Views:	0 Size:	196.7 KB ID:	114387 If the rust had been left in there these are the ticking time bombs that would have made themselves known in the next few years. Hood handle repair metal finished while I still have clear access to the backside.
    Click image for larger version  Name:	IMG_0603.jpg Views:	0 Size:	261.3 KB ID:	114388Primered and painted and ready to reassemble . Click image for larger version  Name:	IMG_0612.jpg Views:	0 Size:	250.8 KB ID:	114389 Getting the original spot welds lined up in preparation for the first tack welds.
    Click image for larger version  Name:	IMG_0613.jpg Views:	0 Size:	238.7 KB ID:	114390Tack welded first at the original gas welds. Then flattened out the leading edge of the lap joint and rewelded over the old drilled out spot welds. Squeezing down the lip again as it went. Happy with how its going right back into place so far. Continuing on with reassmbly.
    Leave a comment:
    replied
    Last of the concerning rust removed.
    Click image for larger version  Name:	IMG_0598.jpg Views:	0 Size:	208.2 KB ID:	114380 Leading edge of the inner frame of course left heavily pitted but surprisingly no holes to backfill.
    Click image for larger version  Name:	IMG_0597.jpg Views:	0 Size:	197.9 KB ID:	114381 Will sleep better at night knowing that this leading edge under pinch seam is now free of rust.
    Click image for larger version  Name:	IMG_0599.jpg Views:	0 Size:	209.7 KB ID:	114382 Skin itself now all clean of that old advanced rust.
    Click image for larger version  Name:	IMG_0600.jpg Views:	0 Size:	259.6 KB ID:	114383
    Only a few additional pin holes have shown up after cleaning. Quickly filled with a gas weld as before.
    Click image for larger version  Name:	IMG_0601.jpg Views:	0 Size:	242.1 KB ID:	114384 Onto getting these surfaces behind a good coat of epoxy and paint then its finally time to reassemble this hood.
    Leave a comment:
    replied
    Quick detour before hood reassembly:
    ​ This deep pitting around the nose of this hood is concerning. The rust has only breached in two spots for the moment but the advanced rust that lurks in behind it will certainly rear its ugly head in the future at some point.
    Click image for larger version  Name:	IMG_0577.jpg Views:	0 Size:	172.6 KB ID:	114373 Same goes for the underside, pitted and with the rust lurking just under that lap joint. There is no avoiding it as the water it will come into contact with is going to run down and settle along this leading edge and no matter how well its seam sealed and painted water always finds its way. After talking with my buddy, now was time to address it.
    Click image for larger version  Name:	IMG_0585.jpg Views:	0 Size:	216.4 KB ID:	114374 Its a complicated area and while both pieces are pitted I am 90% sure we'll get away without a patch repair. Just going to clean thoroughly and seal with epoxy and paint. With the left side out its technically half way there so now most certainly was the time if it was going to be addressed.
    Click image for larger version  Name:	IMG_0586.jpg Views:	0 Size:	268.8 KB ID:	114375 Only surprise is that this area wasn't rotted out entirely. Look at that old water line; this had a pool of water in it on more than one occasion.
    Click image for larger version  Name:	IMG_0587.jpg Views:	0 Size:	246.8 KB ID:	114376 Once the acid devours this rot I'm sure there will be a pin hole or two to close but they be easily soldered shut with a gas weld.
    Click image for larger version  Name:	IMG_0589.jpg Views:	0 Size:	209.5 KB ID:	114377 Though there remains some rust under the right and rear section of the substructure this is as far as we need to go. We'll all be long gone by the time those areas ever become an issue. My main concern is this rusty low spot where the water will try to settle again. Acid bath next.
    Leave a comment:
    replied
    Hood reassembly prep work complete:
ID:	114365 Inner surfaces of all the components cleaned of rust and ready for a coat of epoxy and a top coat.
ID:	114366 Epoxied and followed up with a quick of semi-gloss.
ID:	114367 Ready to begin reassembly; That up next.
    Leave a comment:
    replied
    Hood work continued:
    Click image for larger version  Name:	IMG_0571.jpg Views:	0 Size:	181.7 KB ID:	114359 All the basic restraightening prep complete. Onto the acid bath next for this substructure.
    Click image for larger version  Name:	IMG_0572.jpg Views:	0 Size:	159.4 KB ID:	114360 Hood inner surface all clean and ready for a quick sealer coat.
    Click image for larger version  Name:	IMG_0573.jpg Views:	3 Size:	142.9 KB ID:	114361 While the substructure soaked I went onto welding up the rust damage to the nose. Took a step drill and opened up the rusted out mounting hole just big enough to get past the thinner metal and back to something I could weld to.
    Click image for larger version  Name:	IMG_0576.jpg Views:	3 Size:	169.2 KB ID:	114362 A scrap of old door skin repurposed for the patch. I had to dome it a little first to carry on the profile shape of the skin.
    Click image for larger version  Name:	IMG_0578.jpg Views:	3 Size:	206.6 KB ID:	114363 Patch all stitched in and then gas welded the lower rust breaches closed. This lower edge is not long for this world though. The pits are very deep out here and the backside is just as bad with advanced rust still lurking underneath. I'll have to confer with my buddy to see what he'd like to do. More later...
    Thanks for looking.
    Leave a comment:
    Thanks a lot Roy! Agree, all this work would have been impossible to relay in any great detail but for all the modern gadgets we now take for granted.
  • roy mawbey
    replied
    Justin, really good information and photos on how you have attempted that repair. It would be impossible to put that just into words as you need to see it! Those stage photos are so good . Twenty years ago just not possible to do that so easily on a forum. There must be a few front lids around with the same problems and guys wondering how to correct it ?? Hope they read this!
    Leave a comment:
    replied
    Click image for larger version  Name:	IMG_0562.jpg Views:	0 Size:	178.8 KB ID:	114355 It would be criminal to leave the rust on these inner surfaces while I've got it all opened up so while I worked on the subframe I have the hood bathing in acid outside.
    Click image for larger version  Name:	IMG_0564.jpg Views:	0 Size:	187.6 KB ID:	114351 Discrete little gusset might buy a millisecond or two if the hood ever gets accidently forced down.
    Click image for larger version  Name:	IMG_0567.jpg Views:	3 Size:	206.8 KB ID:	114352 Made sure it bridged right across this stress riser.
    Click image for larger version  Name:	IMG_0565.jpg Views:	0 Size:	217.6 KB ID:	114353 Basic repairs on the lateral substructure run complete. The rest will be fine tuning with the hood as it goes back together. Again the mounting flange will be reset to the hinge resting at center.
    Click image for larger version  Name:	IMG_0568.jpg Views:	0 Size:	225.4 KB ID:	114354 Mounting flange acid cleaned then tack welded across the two halves so it didn't shift or misalign while it was hammered back out flat. Factory locating holes were also welded shut as this is all very much almost like building from scratch again.
    Leave a comment:
    replied
    Mounting flange removal and repair.
    Click image for larger version  Name:	IMG_0556.jpg Views:	0 Size:	198.5 KB ID:	114345 Like the battery box repairs before, lap mounted layers of steel have to be removed for any real shot at getting the base metal ironed out thoroughly. Removal of this mount flange also allows a reset with the hinge centered in its pocked. Touched bottom here as far as disassembly goes. Back to prepping for reassembly.
    Click image for larger version  Name:	IMG_0557.jpg Views:	3 Size:	191.0 KB ID:	114346 Grinding away the remaining shoulder of gas weld to so I can hammer out that slight jog and deformation from the old accident.
    Click image for larger version  Name:	IMG_0558.jpg Views:	3 Size:	212.4 KB ID:	114347 High spots of the deformation in and around the old gas weld.
    Click image for larger version  Name:	IMG_0560.jpg Views:	3 Size:	235.0 KB ID:	114348 damage all pecked out.
    Click image for larger version  Name:	IMG_0561.jpg Views:	3 Size:	210.6 KB ID:	114349 Going to add a small gusset in here to bridge across the gas weld joint where they buckle.
    Leave a comment:
    replied
    Click image for larger version  Name:	IMG_6443.jpg Views:	0 Size:	160.1 KB ID:	114339 I had flashbacks of this hood Roy. It had been run through the mill and had been repaired more than once with the hinge mounting flanges really smacked around to achieve an alignment with its car. While the basic shape was close it was just tired and I could feel it in its structure as the hood hung off the locks. It put me in mind of a sheet of paper that's been crumpled up then flattened back out a couple of times; though the initial shape is back the overall integrity is just not there. A fresh hood would have been my choice but too much had already been invested here by the time the car got to me. Anyway, I didn't want a repeat of this as I'd have to beat the hell out this coupes hood for correct fitment so the best end result was to dismantle the damaged area and build it back up to suit the car.
    Substructure repairs at the center.
    Click image for larger version  Name:	IMG_0551.jpg Views:	0 Size:	218.0 KB ID:	114340 Beating the shape back into the large middle profile rib first then worked out towards the edge. The kink had actually stretched this last section so I had to flatten the lip to get my shrinker jaws on this area to gather that excess back up.
    Click image for larger version  Name:	IMG_0553.jpg Views:	0 Size:	190.4 KB ID:	114341 leading edge rolled back over taking care to add in the curved profile as it went.
    Click image for larger version  Name:	IMG_0552.jpg Views:	0 Size:	151.8 KB ID:	114342 Just a quick mock-up against the skin profile. Promising so far. So glad I didn't have to cut this area out where I had marked earlier.
    Click image for larger version  Name:	IMG_0358.jpg Views:	0 Size:	152.5 KB ID:	114343 Where we started. Looks like that would just pop right back into place but no the kink stretched the area and it was going away easily and especially with very limited access to get behind it. Onto the next deal...
    Leave a comment:
  • roy mawbey
    replied
    Well done Justin well spotted! that must the best way to get over that I reckon but, you just could have just been a bit more lucky and not have had that to deal with too.!! More experience I guess you will never forget. I will be interested to see how this repair turns out as nothing much is ever easy when good gaps are needed.
    Leave a comment:
    replied
    Hood repairs:
    A voice in my head kept nagging at me stop here and make all the needed repairs to the hood first. I need to build around a hood in final corrected form.
    Click image for larger version  Name:	IMG_0532.jpg Views:	0 Size:	490.5 KB ID:	114331 I've repeatedly beat the hoods mounting flange in an attempt to get this hinge centered but it just won't give me the needed movement. The earlier mock up with my hood confirms its the hood and not with the hinge or the pocket.
    Click image for larger version  Name:	IMG_0546.jpg Views:	0 Size:	214.3 KB ID:	114332 Closer inspection shows a buckle and a jog in the subframe that is creating the mount flange misalignment.
    Click image for larger version  Name:	IMG_0534.jpg Views:	3 Size:	149.5 KB ID:	114333 I have three issues to fix on this side. The slightly high crowned profile along the edge( its not all on the fender side) , the mounting flange and the damage to the center portion of the subframe; all from the old accident.
    Click image for larger version  Name:	IMG_0535.jpg Views:	3 Size:	162.7 KB ID:	114334
    I decided the best and cleanest plan of attack was to remove the substructure as a whole at the factory joints. Peeling up the pinch seam, cutting the gas welds and drilling the spots along the lap joint.
    Click image for larger version  Name:	IMG_0548.jpg Views:	3 Size:	196.8 KB ID:	114335 Its out. Now I can go to town all three of these issues with a clear shot at both inner surfaces. This side of the hood has almost no rigidity now so profile resetting just got a lot easier.
    Leave a comment:
    Agree Roy, final engaged hood position can be tricky. Everything is constructed so lightly and with very little in the way of adjustment options once its all welded together and as you mentioned things still tend to shift and change slightly over time. Then of course there is the preload factor of the hood seal itself that affects its final position with the edges of the body. Just shooting for a final fit that requires the least amount of lead or bondo when its all over. Justin
