67 Outlaw bug project
  • 67 Outlaw bug project
    hello
    there s 2 years, I ve bought a 67 zenith blue bug, at the first time, I decided to make a perfect cal look, but to see some 356 outlaws, I prefered to change my direction and make a 67 outlaw bug.
    She was nice when I bought her, some weldings, but no more rust...
    in the beginning, I ve decided to make a "quick restoration" , but to remove parts after parts, remove the body from the chassis was a better job
    I always wanted a sunroof, so I find one and go to my friend who make all the weldings and prepare the body for painting job
    after sanding, welding the went to the painter to spay in zenith blue
    I did the job for the chassis, sanding and epoxy for all, the gearbox replaced by a 8x33 ( 8x35 original)
    Now body found the chassis
    Nice work! What engine/cc's will you be using?
    Mike
    '63 B coupe
      Thanks for sharing your build with us Thierry! Looks like your making some great strides with its progress. So is your mission to incorporate as many 356 trim and components as you can or are you staying with a stock VW body with Porsche drivetrain and suspension? That was a really clean shell to begin with, nice work!
        hi
        for the engine I used my old 1600 of my baywindow ( I removed it to swap with a subaru engine) I ve bought a Scat C35 NOS, kit cylinder 88mm, 1,25 rockers, 010 Bosch with an Empi Transispark NOS, dual 32 NDIX from a 356 on Riechert manifolds and linkage, OT pulley, 356A oil filler. CSP street competition exhaust
        just mounting some parts, before disassembly the engine for adjusting all the parts.
        my rebuilt carbs
        I ll take a picture of the complete engine before restore it
        need to modify the linkage to open the 356 oil filler caps, the linkage ll be sanding and respray in mat grey
        you can see the OT pulley
        I want to make a car like as a man in 1967/1970 in his garage, so I try to use all the parts from this period or replica parts from this period .
        need to go to work ...to be continued
          HI
          for the wheels I m not satisfy with steel 356 respray so I found 4 66 wheels and make them like Runge . Will remove the center of 2 to reweld them on 5,5 with modify offset to fit perfectly with 195/60/15 on the rear
          Use drumskins on the brakes renews
          On the front axle have a sway away and dropped splindles, 4 x 15 wheel with 155/15, i don t know for the moment
          For the body, I made some transformations
          I fitted 356 Bosch horn
          the second one
          the fuel tank in da place
          before painting with the front hood
          the rear decklid is modify in 67 convertible
          a removal rear apron to.
          When I didn t know what can I do, I m going to my garage and drilled some parts
          Oh JESUS !!!!!you can t drill 67 door handles !!......yes I can
          to be continued ....
            Very cool details Thierry! Drilled handles and the filler through the hood are great GT touches! Also like the lightening effort made to the wheels. Reminds me a lot of the efforts made on the Glocker Porsches. The entire the presentation so far is very clean and nicely detailed.
            Nice work and thanks for posting!
              you re welcome Justin
              found a pic of the engine ( the oil filler is not good have a 356 a now )
              the headlights, are yellow with grills , not fit at this moment
              testing on a 67 friend zenith blue ...the flasher ll be white
              my foglight NOS, Marchal 610 150mm
              some badges for the rear decklid (Porsche outlaw and GSR) and on the front... My front hood wad older than a 67 one so I use big trim and front hood badge
              ......next....the interior
                For the interior, I ve found a Nos tachometer, put it in another dash grill
                for the steering wheels, I decided to make one with a VDM who was in my garage since a long time
                after painting, cleaning and fit with a Flat4 GT hub
                Perhaps I ll paint in black the horn button and put a Porsche decals
                the glove box was to old for me so I flocked it, it s easy and make new !!
                all in da place
                For the pedals, I place an order to Kevin Zagar , but have restored mine before and put an assist brake
                but the futur new pedals are more race and lightened
                  the body meet the chassis
                  fitting my 550 handbrake and testing the new shifter , I want a 550 style one but no body can make me one as cheap ( 1500 $ the one at fibersteel)
                    Nice engineering mate, very cool! Cal Bugs rock, and yours is shaping up to be very special. Keep up the great work.
                      thanks
                        for the upholestery, in first, I ve decide to restore all with the original materials, repainting the body seats ( frame ?) in the original color
                        the water blue material
                        all the seats are restored, but want 550 seats , so I found seat frame and ask a friend to make seats for me; they ll be like the original waterblue 550seats
                        to be continued...
                          just bought valve cover
                            Wow this is a great build! I'm particular to this one as my first 2 cars were both 67 bugs. The first I pulled all apart to learn how it went together and the second my Dad an I built into a sleeper. So much fun blowing the doors of the early 1990's Mustang 5.0's! If I really pushed it, it would do wheels over a section of an intersection! Too much fun for a high school commuter!
                              thanks
                              testing the new hood hinge( i don t know if it s the good words) adjusting before painting
