Another long term storage, this time a T-1 Coupe
    Spent the morning heat shrinking and re routing the rear harness. Installed a remote starter switch for maintenance and hard starts. Just a simple 12 mm marine momentary switch next to the voltage regulator. Wire from Batt on the regulator, through the switch to the 50 spade on the starter solenoid. I will also install a hot start relay on this one at the same time. So both the key switch and the button power the coil on the relay. Simple and should be done on all the 356’s.
    Click image for larger version  Name:	IMG_7838.jpg Views:	0 Size:	1.78 MB ID:	116525
    Can you find the secret switch
    Click image for larger version  Name:	IMG_7841.jpg Views:	0 Size:	2.03 MB ID:	116526 Click image for larger version  Name:	IMG_7840.jpg Views:	0 Size:	1.90 MB ID:	116527
    On a funner note today, rebuilding the carburetors. went through the dip. then the ultrasonic cleaner, and blow out the passages with air. I reassembled them, they looked very good, went to leak check and set the float level . I leak check by putting 20cc of gas in the vent tube, and let them sit, then look for shinny or wet spots. Then I run the pump and fill the bowl an check the level.
    Well one wont fill. pump runs, no fuel in the P-Tool. Pop the top, lift it run the pump. no gas through the float valve... Pull the valve, blow through it is good, try blowing through the banjo fitting, no luck, Ah Ha passage plugged, blow it with air, no luck. probe it with wire, it goes through and see some black debris, keep probing, the put a plastic tube form a aerosol can it from the small end and push out the carcass of a beetle from the passage. it was about the size of the passage. I have no Idea how long it ha been in there.
ID:	116528 Click image for larger version
    bug debris remnants on the left, a good carb on right.
      Interesting joint where they grafted in that T5 rear seat pan.
    Not sure on the trans yet. They swapped the nose to a 741 I think, it’s on the ground and hard to see right now. They hacked in a T-5/6 shifter and piece pipe. Then Installed the shifter rod after the trans was in, by chopping some on the center tunnel. Just not sure why, I really need to look at the forward trans mount. Welds are poor but I have not measurements yet.
    Spent the last few days chasing wires, and the turn signal stalk. The wires were chopped off, the single color wires crimped in the ends. Laying on your back under the wheel is so much fun. Not sure about a couple things yet, T-1 used a brass block and screw for connections, now some switched are original for some bullets and some spades. Like the ignition looks like a 911/912 key in the back but wired like 356 with spades and the original key fits.
ID:	116539 Click image for larger version
    Also using ferrules on the new wire connections. They crimp over the bare ends and make assembly simpler
ID:	116541 Click image for larger version
    wires are always so much fun, after simple hydralics.
      I like those termina ends. Yes, very few bullet connections on a T1. Most connections under the dash were spade.
    More component repair, for an almost “completed car”, but it all needs to be done. ( this should be with the T-6 Tank replacement post, Similar but the T-1 has a single outlet straight out the back, PN 644.201.021.00 not up and left like this one PN 644.201.021.07)
    Back to the ultrasonic cleaner. photos are Before…. Then On for 3 seconds…… then 10 seconds later….. it is really fast at first, the goo just jumps off. This was pretty nasty inside after this the pump is probably next.
    Click image for larger version  Name:	76826934477__1A427017-A304-4026-A450-BF16BEDA15EF.HEIC.jpg Views:	7 Size:	335.7 KB ID:	116560 Click image for larger version  Name:	76826935587__AB58AFAC-E10F-4771-8225-B4A38B77DD9B.HEIC.jpg Views:	7 Size:	250.8 KB ID:	116562
    Click image for larger version  Name:	76826938593__DC5FDB08-BD7F-4C18-A86D-A891F776A192.HEIC.jpg Views:	7 Size:	185.0 KB ID:	116561
    Short 24mm wrench, 19mm crows foot. The nut has left and right hand threads, so you turn it down to the base, then screw the nut into the tank, keeping the selector point to the tube you hold it straight with the crows foot and seat the nut into the tank. A bent 19mm might give clearance between the wrenches, but crows foot was fine.
    Click image for larger version  Name:	IMG_2144.jpg Views:	141 Size:	904.9 KB ID:	116563 Click image for larger version  Name:	IMG_2143.jpg Views:	160 Size:	798.1 KB ID:	116564
    If you get a cleaner it “can't be too big”. You can also put parts in a glass jar, with different chemicals and submerge the jar. The sound goes through the glass, works well. I hope to finish the wiring, and get the engine started by the weekend.
      The battery cable is done, dip soldered and just a little longer than original. Too many skinned Knuckles over the years from the original wire length. I think only 5-6 more days of wires, then the carbs back on and it might be ready to start. Tail pipes are fitted, made from stainless, almost stock, probably a little louder!
ID:	116569 Click image for larger version
      Photo of the parade in Levenworth Wa. A Bavarian town over the other side of the mountain on US-2. Their Mayfest celebration
ID:	116567 Click image for larger version
      thanks for looking
        Cable end looks good. you do nice work. Like the stance on that A coupe with the hood straps.
      The saga continues, today I passed 2000 miles driving down and back to the storage facility. But the new starter system circuits are in. Put a hot start relay and remote starter switch in. The extra long battery cable worked out better than I expected, I looped it over to the right along the first 3 loom tabs the back over across the top of the starter almost to the clutch cable and then back over to the solenoid. Fits snug but I think you could unbolt the starter and pull it with the big cable attached. Yes with the 3/0 welding cable attached to the solenoid bolt. ( Disconnect the battery before trying this ). The dash wires continue to be a challenge, lots of wire stubs to translate and terminate.
      Shifter will also be a challenge. Boob chopped it up removed the monkey motion parts, and cobbled in about 3/4 of a BC shifter system , put a T-5 shift coupler, and a 741 nose on the trans with a T-5 dual front mount. He Split the tunnel because the put the trans in before the peace pipe rod, then Tacked it back together. Major problem will be the shifter movement. The stock T-1 long shift lever and monkey set up has a 4” lever advantage between the shifter pivot point and shift rod. The T-5 is only about 1-1/2“ so the shift knob needs to move twice the distance for engagement between gears. 356A’s were pretty famous for long throws, this on is almost twice as far, the H pattern in 18” wide. Not sure about a cure, maybe arm extenders. I think I found all the gears today, reverse will be especially difficult but I think achievable
      Replaced the bad rear brake pipe to the LR cylinder. Good news it fits, bad news, it bleeds , but no firm pedal. Did not spend allot of time trying to get it to bleed, I believe the master cylinder is bypassing internally. Too many bad wires still to worry about stopping.
      Carburetors back on, I hope to move on to the engine for a while. Will start with valve adjustment, then a leak down series. If that looks reasonable, then compression test. After compression and oil fuel pressure validation, we will do a full electrical tune. I need to put the muffler and tail pipes on before trying to start it. Debating clamping or welding the tail pipes, it a Dansk muffler, so I know I will need to measure and straighten and parallel the head flanges. The tail pipes are .087 wall 304 stainless tube, so I may laser weld them. That will give me something solid to pull on.
      but we progress, thanks for following.
        I hope she appreciates your effort, especially the miles you're accruing. So you have to make this shifter puzzle work? She won't go for a 644 nose cone with the correct shifter tower for 356A. Money might be issue? All those parts would run some money now that I'm thinking about it.
      Another day in the books. Not too much to report on the 356. Have a good Ferrari story today.
      Jim Simpson who owns the facility I am working at, is a factory trained Ferrari guy. . He had a 308 trailered in from the upper islands, please diagnose “ running poorly” . Did you know a Ferrari uses a polystyrene distributor rotor! No kidding like a styrofoam cup the cheapest but lightest injectable plastics The carbon button stuck, allowing an arc between the center cap and rotor, that arc heated up the rotor, it started to melt and the spinning spread thin threads like Cotton Candy Inside the cap. I have never seen what looked like very fine spider webs inside the cap. At first we thought it was spiders, but a closer look, it was melted rotor threads. Go figure.. Ferrari. Nice looking but lots of cheap stuff inside.
      if you see spider webs in your Ferrari distributor , take a close look at the rotor.
        The 356A monkey motion shifter is all gone, but the T-6 selector lever does reach all the detents. It’s miserable loose, the throw from 1st to 2nd is 20” long, it works like a bent shit can lid, “ You can make it fit, you just need to work on it”. I will know better after I can drive it. It’s like driving a tractor trailers truck, the throw is so long the shift knob just ends up in a different county.
        More wiring today, made a new wire harness for the rear lights. Boobb replaced the rear bee hives, but ordered all fronts with dual post bulbs. I had Celeise order a Vintage Trader 356 T-1 LED Kit. But the reproduction front sockets use a dual filament bulbs. I had built the harness to light up both lights and use both filaments. That was easy with a jumper since the left and right are split at the fuse box. Now the LED bulbs do not for the sockets. I called Jules at VT when I realized the sockets were wrong for the original T-1 kit . He immediately knew what had happened and had new bulbs in the mail in under an hour, and no charge. That’s customer service!
ID:	116577 Click image for larger version
        Boobb chopped off all the wires under the dash, everything is short, even the main power cable between the battery and fuse box. . It’s a real mess but we are slowly overcoming all the defects. The light control relay is missing, and unobtainable. I can use a modern double pole single throw relays to replace it. Might be better in the long run.
        I still have not started on motor or transmission other than rebuilding the carbs, every time I clear something on the list two new things show up. Now the master cylinder needs rebuilt. Even worse it been 50 years since I worked a T-1 this deep. Many things I forgot about these early cars. But I hope to have it driving and reliable by July.
          Not much new. Another week of wires, the more I look, the worse it is. some mufflers parts came in, so I can fabricate tail pipes. Photos show the ferrules I use on the wires. These make stranded wire easy to manage. They crimp around the bare wire. Shown is the new harness into the beehives, works well. The crimp tool and kit is pretty cheap, it makes life easier. The authenticity police might not approve, but some things have improved over time.
          Click image for larger version  Name:	IMG_7950.jpg Views:	0 Size:	874.0 KB ID:	116600 Click image for larger version  Name:	IMG_7952.jpg Views:	0 Size:	1.22 MB ID:	116601
          Click image for larger version  Name:	IMG_7953.jpg Views:	0 Size:	1.60 MB ID:	116602
          Had a get together Saturday and drive over on the Olympic Peninsula, good meeting in spite of the rain. Mostly 911’s but several 356’s even with rain. I drove my 912, and Celeste (cars owner) came up for the day. Visited a very interesting car collection, with hundreds of motorcycles. She is in the photo with the burgundy coat in front of my “deer hunter” 912. Raised with 215/15 light truck tires, it just rips up the old mountain logging roads up in the national forrest.
          Click image for larger version  Name:	IMG_2160.jpg Views:	0 Size:	620.6 KB ID:	116599 Click image for larger version  Name:	IMG_2165.jpg Views:	0 Size:	502.3 KB ID:	116598
          tool link:
          https://www.ebay.com/sch/i.html?_nkw=ferrule+crimping+tool+kit
            Looks like it was a nice turnout of cars. Is front bumper of your 912 black on purpose or is that on the to do list?
          ONE WIRE AT A TIME. Well after a couple weeks of wiring I think I can see light at the end of the tunnel. I never realized how bad someone could mess up a wiring harness.. And if you cut the wires to the flasher, or light relays or splice wires together with out matching the color codes. We have been starting at the bulb a working back to the fuse box, or turn signal selector, one at a time. I could not believe he cut the stalk harness 1/4" below the disconnect bullets and then spliced in a foot of red wire into the stalk, but did not match the original color codes from the harness. I do have Greg Bryant’s big windshield size color wire diagram, with out that I would have had to punt this one.
          Click image for larger version  Name:	rear lights1.jpg Views:	0 Size:	475.7 KB ID:	116637 Click image for larger version  Name:	rear lights4.jpg Views:	0 Size:	417.8 KB ID:	116638
          We have been starting with color code, then meter to the fuse box, then on to stalk switch or relay. After a good trace, inject power into the wire, if not too big of a voltage drop then test with a bulb.. one wire at a time. Cant believe how many miss connected wires there are. Also the 8Ga from battery to the fuse box was clipped right at the conduit above the battery. I sid manage to get a new battery cable in a couple weeks ago an a hot start relay with a push button next to the voltage regulator. I have finally crank the engine over and have oil pressure. The starter wire (50) is shorted into the ignition (30) somewhere so if you connect the battery to fuse box wire, touch the key and the starter runs. Never seen that before.
          Click image for larger version  Name:	rear lights2.jpg Views:	0 Size:	509.8 KB ID:	116639 Click image for larger version  Name:	rear lights3.jpg Views:	0 Size:	520.4 KB ID:	116640
          Click image for larger version  Name:	IMG_8015.HEIC.jpg Views:	0 Size:	1.49 MB ID:	116641
          jumpers, a kludge a couple bypass & work arounds and some extra wires but the original lamps finally light up
          BOOB ordered new reproductions but the wrong beehives, all dual filament fronts assemblies. I had Celeste order a T-1 LED kit from Vintage Trader, I called Jules, told him of the double filaments, and he sent new rear bulbs at no cost. I wired them in parallel so you now get two turn signal or four brake lights. Way brighter than the original bulbs.
          I can believe it’s been almost 90 days and I still have not got to the motor yet. I did oil the rings and finally spun it over, got oil pressure and oil flow into the filter housing. Leak down and compression checks next, then on to the suspension. All the front end bolts are finger tight, the gas tank looks OK visually, the steering box and trans are still dry. But we are getting close. Celeste found an original Washington plate and a 56 year tab. We hope to have it re-registered and a new title in a couple weeks. The 356 Groupe annual Bull Session is the 18th of July. I hope to have it done by then.
          Justin its black, It seems to skip off big rocks up on the logging roads, its easier to rattle can black on the scuff marks. its really a kick about 50-60 and power slide the curves.
            LED's are the only way to go. He includes the blinker unit but its for the later T2 plug in socket that the T1's don't have. Have you got one for this conversion?
          Justin: I will make up an adapter, all the wires are cut off anyway. I also need to make a head light and horn relay circuits with modern relays. Missing lots of electrical things.
          I did swap out the headlights with led’s today. The previous Boob did not but the buckets back together correctly. I need to order some springs and rubber pivot kit. I think the buckets can be saved but there is no way they will adjust like they are. The old reflectors were cobbled together, they were painted black and sheet metal screwed together. Every time I start something it seems Boob was there first.
          Click image for larger version  Name:	IMG_8052.jpg Views:	0 Size:	1.19 MB ID:	116663 Click image for larger version  Name:	IMG_8050.jpg Views:	0 Size:	1.24 MB ID:	116664
          Click image for larger version  Name:	IMG_8051.jpg Views:	0 Size:	1.36 MB ID:	116665 Click image for larger version  Name:	IMG_8053.jpg Views:	0 Size:	1.66 MB ID:	116667
          Click image for larger version  Name:	IMG_8048.jpg Views:	0 Size:	1.59 MB ID:	116666
          Nothing like pulling a light bucket, and find 4 retainer springs laying in the fender bucket, and 22 gauge wire & spades on the headlight plugs, and some 0.010 safety wire holding the entire mess together. Plus the glass lens was loose with the inner seal popped out.
          I did get a leak down and compression test done, both good. But the valve covers are both glued on. I have no idea what he used for sealant, but man I have never seen any stuck like these. Tried a heat gun , but did not get too far. Gave up and just crossed my fingers on valve adjustment. Since the leak down was better than 90% and no real noise from the carbs or muffler, I did a compression test. That had 120psi, so it will run. I figure the rings are just still a little dry from sitting. I did get a good pre-oil through the plug holes a few weeks back, so I hope it wicked well.
          should have it running this week. I need to go through the fuel system. The tank look good but I need to look at pump the hoses and pipes. Then do leak test, pump pressure. I did the carbs so we are close. I need to figure out the valve covers. Adjust the valves, verify the push rod and valves rotate when look at the oil flow to the rockers, lots of petty stuff, but I did not put it back together, and Boob did not know what he was doing.
          thanks for looking
            I don't doubt your skills for a second John. A man who can build his own dyno from scrap parts can figure out just about anything that gets thrown his way.
          Got away from wires for a weekend. I got all the way back to the turn signal stalk, ran into 8 red wires, spliced into the harness. They are cut at the bullet plugs, three you can see the color code, the rest are over sprayed with paint, all the old wires have green on them. The meter will tell but I am really tired of laying on my back under the dash. Can’t find the wire segment between the master cylinder and stalk for brake lights.
          Spent Saturday installing the bumpers, yea 5 hours on a bumper… I think Boob bought new attach bars, they shipped with the car but not with the bumpers or nerf bars. The rear nerf bars were 8mm off from the slots in the bumper bars. . The front fender braces are welded to the bumpers mount, not below them. The bumpers almost align, just another item of the list.
          Click image for larger version  Name:	IMG_8071.jpg Views:	0 Size:	1.34 MB ID:	116690 Click image for larger version  Name:	IMG_8072.jpg Views:	0 Size:	1.25 MB ID:	116689
          Click image for larger version  Name:	IMG_8073.jpg Views:	0 Size:	1.55 MB ID:	116688 Click image for larger version  Name:	2298194587824460187.jpg Views:	0 Size:	221.7 KB ID:	116691
          Vintage photo.
          Filled the transmission with gear oil. Serviced the steering box, 50/50 90w gear oil and molybdenum grease. Could not find the 160W oil anymore. Put 50cc of gas is each carburetor float bowel, another 17 cc in the fuel pump inlet hose. Multi meter back on the oil pressure switch. Hot wire from the coil to Batt+ on the voltage regulator. After a few minutes soak, it fired right up in 2 revolutions. Ran the engine for 20 seconds. A little smoke at first from the pre oil in the cylinders, cleared and idle settled out. Oil pressure switch opened on start, stayed open 10 seconds after shut down. Fuel pump worked, had fuel to filter
          No strange sounds, re ran the startup video several times listening for noises, seems OK. I was reluctant to start it, still a little worried about the valve train. I have not checked the valve clearances, push rod or valve rotation, oil flow, It seems Boob was worried about valve cover leaks. So I’m not sure but I swear he used JB Weld to seal the valve covers. I spent 1/2 a day trying to get them off. I tried heat, rubber hammer, several different prying techniques. They will not budge. I might need to pull the motor and tins to get at them.
          The engine had been dry for years, when I did the compression check, I had the filter top off, and a gauge in the temp sender. Pressure is 30-33 psi, flow at the filter inlet. So the saga continues.. I will probably drive it this week, move it from storage up to the shop. That save me an hour a day on the drive, at a now been 3800 miles of back and forth to the storage location.
            Always interesting to see the creative ways guys come up with to do things wrong. Five hours on a bumper I can surely imagine as the time slips by quickly as you're wrestling with things and trying to unwind what was done. You really are on triple duty here old friend and the milage you've accrued just to get this far is really mind blowing. I hope you can get it back to your place soon and I also hope she appreciates the effort that is being spent here.
        • #27
          Well was a goodish kind of week. More wrong or broken wires to fix. I think Boob is colorblind, if he works on his house it will burn down. We got it to crank with good oil pressures . Then went to do a static tune up to start. Points plugs static timing. Filled the carb bowels with gas, it fired up sounds good, no knocks or squeals so far. But just a couple 30-45 second runs before it ran out of gas. Tank still dry, bad fuel valve to rebuild. Went to look at the valve adjustment, and Boob put the valve covers with what looks like JB Weld. I picked and pulled every way I know of and they are stuck. Probably need to pull the motor and get out the big torch, get the cover red hot and burn off the glue. And the front flywheel oil seal is leaking , and both axel boots have the joint pointing straight down. When we added fluids on Monday, we found leaks everywhere.
ID:	116757 Click image for larger version
          We got it up to our shop today, so that will cut my commute in half. When we started it in storage facility , it went straight up on jack stands and in to evaluation. All the front end nuts were only finger tight. Today when I put the tires on they have 1/8” clearence between the tire and fenders. They are scary close. The have not rubbed, I put the spare on it has 1.5”. The wheel’s Boob bought are 6” wide when a huge outer off set. The inner rim is about 8mm off the lower shock mount, the spare wheel is 5mm. So that’s close on the inside, but that’s a fixed clearence. The outer is very close, the reproduction wheels are just too wide. They may work on the road but it’s the smallest clearance I have seen. .
ID:	116755 Click image for larger version
ID:	116754 Click image for larger version
          here are photos of the clearence between the aftermarket (L). and original wheel (R) I can get a couple fingers between the spare and the finder , from the outer edge of the fender the depth gauge says it is less than 3/8”
          but the good news it’s up at the shop with everything I need to pull the motor and the rest of the tools. I am shooting for a driver next week, we have an annual 356 Groupe NW BullSesaion on Sunday 19 July. This old girl needs to be there.
            Congratulations on finally getting it back to your shop, the progress will really get going no doubt. Interesting bumperette/nerf bar. Paper thin clearance! As kid the deeper the rim offset the more I liked it. Now however, its the exact opposite. Most cases I'm longer a fan of super deep dish wheels especially on a flat fendered' 356 but 60's muscle with an old school Crager still works and so does a deep Fuch wheel on a real 911 Turbo.
        • #28
          Replaced the fuel cock yesterday, leak checked it over night with a single gallon, all is good, no seep. . The turned it on while up on jack stands seemed ok but the car was a little nose down while I finished the rear wire loom. Then went to put it back on the ground, and crap gas leak at the rear fuel pipe. Leaking about a drop a second. Fuel back off!
ID:	116773 Click image for larger version
          Thought it was a loose or bad hose, but OH NO Boob sandblasted a hole in the fuel pipe, right where it goes through the body. Making a new pipe tonight. Did get the rear wires wrapper and routed. Still have a few wires under the dash to find, but it’s coming together.
ID:	116770 Click image for larger version
ID:	116771Click image for larger version
          But each day it gets closer, it’s been a real journey. A few bullet connectors on the headlight light and ignition switches to replace. Then rewire the turn stalk, horn button, light flasher thanks for following.
            So many peripheral repairs...Good thing its close by now. Keep up the great work!
        • #29
          John my goodness you have been busy of late. You made me grin talking about Boob and his efforts to keep you busy repairing things.
          Always some good photos from you to explain!
          • #30
            Yes, I think Boob should be charged with elder abuse. To do this to a 70 year old car is criminal.
            Finished the lights finally today, what a struggle. Someone broken/ cut wires. Over spray in black or green. Some twisted together, bad splices, The turn signal stalk was incredible, one missing wire, 3 miss-wired to the incorrect circuit no power from the brake switch and the flasher sub harness was cut off in the harness. It would have been almost easier to put in an entire new harness. But they all work today finally. Then went chasing the generator light. The generator won’t motor or polarize, the blue wire to the light was tied to field at the regulator. On first engine run, I quickly checked for generator voltage, we were good. . Little did I know I was reading the battery through the red light. If someone else worked on it check everything. Mow looking at a Tudor 6v alternator.
            Did a quick electrical tune up, points, timing, Carburetors adjusted and balance set, minor tune up stuff. Starts on the first crank! idles at 600RPM, sounds strong and solid. Has some smoke but it just ran for the first time in 17 years. Still have not been able to get the valve covers off to look over the valve train. (Don’t use JB weld on valve covers). Has a pretty good front crank seal oil leak, and the axel boots seams are pointing straight down, yes screws at the bottom, so you can watch it drip. But other than a couple annoying leaks it’s coming together. It’s amazing every fluid I put in this on had a leak somewhere. Things cross threaded, on not tight, or eroded away by the sand blaster.
            but I think I will try to drive it in the morning, please cross your fingers
