Thursday update. Engine back in and running well. All the instruments work, lights signals work, heaters defrosters good. No leaks except the sump, but we will fix that on the next oil change a 250 miles. Should drive it tomorrow for the first time in 38 years. . Need to squirt some primer on the bare spots but over all looking well overall . I know the fan belt is on backwards, but period correct.
Took a minute to test a Tudor Alternator in Tom Olson’s B Coupe. The original install had a 8.2 volt output after a couple hundred miles. Worked well just a little high on the output voltage. Emailed the vendor in the UK, they sent a replacement at no cost.
This one was 6.9 volts, a little low but still just fine. Got about 10 amps out of it, but this car has a Vintage Trader LED set so there are not any large electrical loads available. I thought the 8.2v would be fine, the battery is a pretty good filter, but was concerned about boiling out the water in the battery.
I will post a YouTube of the first drive “search on alcohol free gas”.
thanks for looking..
