Engine thoughts
  • Engine thoughts
    I have to start thinking about an engine for the car. It comes with a 1600 VW type 1 as standard but i can upgrade that or source my own. Im not really that au fait with engines and how well a 1600 may perform.
    Any thoughts or suggestions. Is a 1600 enough to keep up with modern traffic on the freeway? Would a 2100+ be too over the top or maybe in between with an 1800.
    Or a Porsche engine of some description. maybe a 912? or more modern.
    All suggestions welcome. Thanks!
    Consider a Subaru boxer 4 cyl. 2.2 or 2.5
    Moderation in all things - resistance is futile
      Here's another option
        If you considderthat most 356 cars were in the 70-80hp range and a 1600 beetle engine should have about 60hp it is pretty close. Add twin carbs,slightly higher compression and 70 hp is within reach without breaking the bank
        armand
          Thank you for the suggestions
            Chris,
            What Armand says is right to the point. Of course if you want more grunt then other options. I reckon a 1600cc well sorted, will keep your car up with the normal traffic just fine. My super engine with 75 hp has no trouble.
            Remember a 356 engine or 912 is fine but if its well worn it will cost you a lot to rectify. Its the way you go, not always how fast it goes!
              A good compromise would be a VW Type 1 at 1715CC.
              It will reliably put out about 90 to 100HP all day.
              Easy to build as well.
                Thanks again all good suggestions. I like the sound of all of them!
                  My original dream powerplant was a punched out type-4 with a 911 fan shroud assembly.
                  I spent many an hour in an old Fat Peformance cataloge dreaming about this engine. For me personally, I have no use for a Porsche push-rod motor. Thier more money and less HP when the dust settles; wouldnt bother me a bit if the crankcase reads VW so long as it kicks ass. Never really considered a type one though Greg Banfills motor has completely changed my view on that. Take a look here:http://www.abcgt.com/forum/6-Hot-Rod--Modified-356/28251-My-54-Coupe-that-we-call-Curb-Appeal.html?limit=6&start=102
                  There were some great videos of it here but youtube has been screwing around with thier format and have since disappeared.
                    Thanks for that Justin. Looks cool!
