Trick Parts
    Hi Joris
    Capricon offered me one and I had the choice of the 80 or 82. Capricon can do just about anything they want to do and they don't seem to care about the ROI. Unlike some items rebuilding a roller crank does not restore it to new they were meant to be serviceable to extend the life. I believe that rather than bandaid the few existing cranks we produce a new 1 piece crank that is a throw away at end of life since the cost of a new crank could be comparable to the cost of servicing the present ones and much less expensive than remaking them when they won't ever need servicing anyway.
    j
      Pumps close to being done now. All housings have been computer measured and gears will now be ground to each housing to ensure perfect clearances and thus pressure.
      And one sneak peak of a project a friend is working on
        Thanks Joris, That is impressive! Looking forward to the updates!
          Hi a hybrid crank that Al Cadrobbi did 15 years ago just got into a motor that used it and it will go back together so i thought i would share.
            Hybrid? So a roller/plain bearing combo for a 547? Interesting, thanks for sharing Jacques.
              actually this crank is 587 74mm stroke the 587 engine case was only modified for the roller thrust brg
                  547 pumps can be bored out for the 692/587 dia gears they share that dia with the 912 and the 911 also. you purists can go with the smaller gears.
                    That is a nice offering Jacques! As valuable as these motors are I think I'd opted for the larger pump gears.
                      i had gears made as blanks 50 and 36mm long the 36 works for the 356 third piece there is a little overside on the od but not a lot to regear the 547 pump was fairly straight forward it took 3 50mm gears to make the 4 gear set. by my calculations not counting the repair of the housing we should increse the volume by 21% since the OD is bigger and the root dia is smaller.we could have also bore the pressur housing deaper but salvaging the pump was all that was needed.
                        Cool stuff Jacques, see you tomorrow
                        • #27
                          repairing damaged races on roller cranks should be satifactory for occasional use.
                          • #28
                            Jacques, Earlier you posted a shot of your new annular disc brake rotors, do you by chance have a photo of an original annular disc brake front spindle? Thanks! Justin
                            • #29
                              New 547/1 engine cases. These are made by a friend of mine. My case was used for the initial scanning and CT scan
                              • #30
                                WOW Joris, that is absolutely gorgeous!! Is a proper roller-bearing crank in the works as well?? Same outfit developing your heads??
                                Thanks for posting!
