Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Canuck 1960B T5 Coupe Resto - ABCGT Forum
  • A few updates. Roll bar shape now complete nicely hugs the body shape by 3/4” Off to get media blasted then epoxy coated and sanded before paint. Wire loom is in and tucked Click image for larger version
ID:	117266 Click image for larger version
ID:	117267 Click image for larger version
ID:	117268 Click image for larger version
ID:	117269 in place in the rear. Black Mercedes insulation glued under transmission tunnel then two coats of black rustoleum. Rear firewall all tucked in With noise proofing (a few layers to fill in voids between ribs.
    • Installed refurbished numbers matching transmission. https://www.facebook.com/share/r/18d...ibextid=wwXIfr Click image for larger version
ID:	117271 Click image for larger version
ID:	117272 Click image for larger version
ID:	117273 Click image for larger version
ID:	117274 Click image for larger version
      • Most exciting part of the build for sure, Its looking great!
        • Yes it really looks super well done indeed !
ID:	117279 Installed 6volt electric fuel pump and finishing up frunk sanding and prep for paint. Click image for larger version  Name:	IMG_7604.jpg Views:	0 Size:	1.88 MB ID:	117280
              It all looks clean, neat and well planned. I like the hardline plumbing and mounting of the pump down in there. Nice work Scott!
          • My friend Dave was able to source a rare NOS hirschmann centre mount antenna. Temporary window installed along with the windshield wiper mechanism to ensure that the mounting hole to be drilled and bottom mounting bolt wouldn’t interfere. Also wanted to ensure the wipers would have clearance. The antenna is then angled upwards to the roof close to parallel to the windshield. On the roof a holding clip will also be mounted to secure the top of the antenna. Love the look of this rare accessory. Here is a pic of Mr porsche with his early VW and a centre mount antenna.​
ID:	117293 Click image for larger version
ID:	117294 Somme more photos of antenna installation
              • Happy with where it is positioned. Click image for larger version
ID:	117297 Click image for larger version
                  Very unique and a very cool old piece!
              • Final wet sanding prior to paint. Still using guide coat as final check. Using wet surface and grease and wax remover to generate reflections as well to confirm curves and straight surfaces.
                • Body paint done. Three coats of base Bali blue with black tint. Five coats of clear. Time to cut and polish. https://www.facebook.com/share/r/1As...ibextid=wwXIfr
                  • New firewall. Motor installed and Sebring exhaust mocked up. Spark plug holder installed as well.
                    • Well done Scott the work carried out looks very nice indeed.
                      • Thanks Roy nice to be at the putting it together stage Click image for larger version
ID:	117338 Click image for larger version
ID:	117339 Click image for larger version
ID:	117340 Click image for larger version
ID:	117341 Click image for larger version
ID:	117342 . Here are some updated shots of body. Wet sanding over a 1000 now and higher. Getting there. Really solid mirror finish.
