Canuck 1960B T5 Coupe Resto
Think I should paint the inside of this cavity before I weld in the vin panel. I have epoxy coated but need to learn about finishes. What paint gets sprayed in this area and is it later coated with gravel guard. Any guidance on what is required and colours would be appreciated. ? ?1960 356B T5 - under major resurrection.
Area to be painted or sealed
Last edited by JTR70; 07-26-2019, 07:07 AM.1960 356B T5 - under major resurrection.
- Likes 1
- Likes 1
So the issues for the drivers door.
1. front bottom edge of the door binds on the bottom of the rocker drip try. May need to try to lower the try or create a subtle depression.
2. The front outer door skin extends out slightly from the rocker panel. Not sure about next steps here. Try to draw in a bit when I put on the lower door skin by shaping the lower door panel bottom a bit or slice the rocker threshold to push out a bit.
3. The lower rear door skin does not extend out enough to be flush the rocker panel. Same issue here try to adjust the door panel insert to push out the door skin a bit or cut a pie on rocker threshold to draw it in.
- Likes 1
The passenger door is lined up but a significant problem with the new b-pillar panel. The lower third of the inner door is bumping up against the rubber seal form. And the width between the door and the rocker threshold is not straight o by the time the inner door reaches the b-pillar the is not gap.1960 356B T5 - under major resurrection.
- Likes 1
Tried a scape piece to test buck for shaping the edge. The front corner is odd. It starts with just an 90 degree bend following along the vertical leading edge of the door the transitions to a full fold over along the base of the door.
also drilled led out the welds on the front rocker so I can pull it out a quarter inch to line up with the door which is a little proud when aligned with rocker.1960 356B T5 - under major resurrection.
Your missing a flange section on that rear vertical wall where that seal channel is. Here are some shots I took when I dealt with this area:
First two are factory.
The need to lap each other for the joint. Again yours is missing the flange next to that seal channel section.
More details here:
Hope this helped.
Thanks Justin for the images. I had previously made the flange along the seal ledge so roughly positioned. I recal that I had wanted to wait to put it in later but before I had welded in the inner trunk panels - unfortunately they are welded in now.
I thought I had seen a previous picture with this lapping on top but if I understand your image correctly the flange sits under inner panel? Is this correct that flange sits under?1960 356B T5 - under major resurrection.
