This is a sticky topic.
I didn't know where to stick this so I started a new thread. Post up any specialty stuff you use here to pass along to everyone else. Many times a certain product or tool gets mentioned in one resto thread but then gets "lost" as no one remembers it's there.Mic
1959A coupeTags: None
- Stuck
Eastwood internal frame coating. I found this thread on the Samba.
http://www.thesamba.com/vw/forum/viewtopic.php?t=417184&postdays=0&postorder=asc&start=0
It seems like it gets good reviews & works well. Comes with a long tube to reach way into hidden cavities. Also has a special nozzle that sprays in a radial pattern for better coverage.Mic
Great thread topic idea Mic, Thanks for starting it!
Eastwood actually sells a lot useful stuff. That deep reach sealer looks interesting.
Here's my first contribution: The Peddinghaus shrinking "twist head" hammer.
My newest metal bumping hammer of choice for shrinking/dolly work. I absolutely love this thing! If I ever lost or damaged it I'd be on the hunt for another! My good friend and metal fabricating guru Jason Bobruk from Australia introduced me to this tool several years ago.
I remember seeing this hammer offered from Eastwood since the early '90's. The head is spring loaded and encased in volcanized rubber. This unit slightly twists from the force of the blow and gathers the metal. I always thought of it as just a gimmick item but it works beautifully and gives a great positive feel as you work the metal. I would compare it to almost working on a shot-bag. The blows feel dead and the metal absorbs it and complies. Unlike a ball-ping/ dolly blow that is more high-pitched and rebounding and feels like it moves or contours the metal very little.
Here is the maestro himself Jason Bobruk putting on a clinic the day he and his father showed up to help me with this "sows Ear". It was a silk purse again when this session was over. This hammer really shrunk and leveled out all of that old damage beautifully! Being in the hands of a master metal man of course made all the difference but its potential was made perfectly clear. My thanks to Jason once again!Justin Rio
It is my most cherished finishing hammer...
Here's another great product: "Zip" wheels by Walter
These are by far the best cutting discs on the market. My buddy Warren Mesick (who fabricates and builds off-road racecars) introduced me to these about 10 years ago.
What makes them great is that they are about half the thickness of a normal standard cutting disc(pictured on the right) and once mounted they literally "sing" right through sheet metal. They also make short work out tubing and heavy plate. They are the best!
The other great thing is that they last! These are not cheapie Chinese versions that disintegrate after a few passes. You'll be amazed with how much cutting you can get out of just one disc. The other cool thing is as it wears it gets just a little thinner making cutting that much quicker.Justin Rio
Saw that picture before...ouch!
I always bought the more expensive zip wheels but figured I would try the 10 for $5.00 wheels since I knew I was going to do a lot of cutting that weekend. The first one I used would barely cut through the metal and the next two shattered. Found a couple pieces in my garage door and last week saw a huge piece stuck in my ceiling. I threw the rest away!
Phil, thanks for sharing that tin-snips tutorial! I learned a lot new things and the finer points to the design of these tools!
Yikes! That is a nasty injury! That's how quick it can happen. That's one tough Vato though even with half a grinding disc in his face he still kept his shades on. That site has all sorts of crazy and disturbing shots.
I tried the cheaper discs too Frank. You save no money because they burn up twice as fast.
Thanks again, great stuff!
JustinJustin Rio
