Convertible D top frame hinge dimensions needed
  • Convertible D top frame hinge dimensions needed
    Hi Guys
    With weeks of self isolation about to take effect I find that I have some time on my hands so I thought I would try and reverse engineer a couple of hinge brackets for my Convertible D project.
Name:	Con D top.jpg
    This is where I need your help, I could do with some clear high resolution pictures of the part from the top and the side (as straight on as possible).
    I also need some key dimensions (see my diagram).
Name:	Convertible D top frame bracket.jpg
    And lastly is the rear bow (the one that is bolted to the rear bodywork) a hollow tube or is it solid and drilled out either end?
    The cast piece that holds the rear bow is going to be a real challenge so if anyone has any of these pieces lying around please let me know.
    Stay safe
    Drew
    I'll get you some detailed shots of this early D top frame I have here Drew. As for the base bow its just hallow tubing. Contact Ric as I sold him an original D base bow a few years ago and he still might have it.
ID:	108074 The hinge joint is simply a lopped off Speedster seat hinge.
      Gas a little gas weld tack to keep the pin from walking out.
ID:	108076 Call Stoddard and get a pair of brand new ones and you're off and running.
ID:	108077 Width of bracket where the hinge welds to.
      Base bow tubing is very thin gauge tubbing as you can see this one is split from the tension.
ID:	108080Click image for larger version
ID:	108081Click image for larger version
ID:	108082Click image for larger version
ID:	108083Click image for larger version
        Hope these helped...
          Hi Justin
          Thank you so much, this is just what I needed.
          Stay safe
          Drew
            Great Drew, let us know how its going...J.
