1961 Sunroof Coupe - The slippery Slope.
  • 1961 Sunroof Coupe - The slippery Slope.
    3 years ago I acquired this car from a friend, he originally had 'sellers remorse' but that very soon disappeared as I started to look more closely at what he had sold me !
    We are still good friends ! My original intent was just to do a quick paint job and enjoy the car and have some fun, somewhat naive in retrospect.
    My skills were pretty limited when I started and I made some choices I regret, but mistakes make us human and lessons learned etc. Feel free to ask any questions ...
    So as can seen I built a tip over frame
    and made mistake number one: the wheels. To small and too far inboard and complete waste of time, broken off several times so spend the money and go big !
    and weld those wheels strongly !
      Started chipping of the old sound deadening paper and tar. An old wood chisel worked well as well as a heat gun. Removed the gas tank to find a rotted out gas tank floor. Being cheap I decided to make a section myself.
      Humm easier said than done, but it looked OK - well sort of. I made and welded on one rib as I had no means to press anything; several months later I ripped it out in disgust and brought a vendor replacement. Lesson two: unless you are good and have the skills the time and effort aren't worth it !
      But the quality of the new floor frankly sucked, badly finished and welded and I can't see why it was sold and I should have returned it. Lesson three: Don't be shy to talk with suppliers - if it is cheap understand why ! (I was suckered !)
        But at least I could add the two gas/water drain tubes back in that had rotted off
          When you don't know where your going, its hard to make a plan how to get there ! I thought I could "just" do something simple, clean it up and have fun all in just a few months. I had no idea I would be doing a bare metal repair job ! Once the old under seal came off - why put new right back on ??? and while at it do the front steering etc.
          This all had to redone after paint overspray got everywhere ! Even though I thought I had it masked everything off well. "Well" was not good enough. Lesson 4 - plan and think ahead and most of all, don't put top finishes anywhere near areas that are going to need extensive work. That is so obvious now ;-(
            Don't go digging in the dirt (aka bondo) unless you take antidepressants first. If you look closely at the head light bowl rim you see there is no rim, it smooths right out to nothing...
            So I started to dig
            and dig some more
            and some more
            and then got very depressed...
            but even better was to come !
              Hi UK in USA,
              So you ended up on the wrong side of the pond
              Nice to see one more 356 getting pampered.
              You will learn alot on your journey to fix it....as you already pointed out.
              But heay there is alot of help on this forum if you need it
              Looking forward to more photos from you.
              Cheerio
              Per
                UK
                Welcome aboard. Lot's of us have been through this or are going through it now. My front end was similar but filled with lead. Am working on it now under "The Resurrection of Foam Car" thread. Where are you located?
                Phil Planck
                  Hi sorry should have completed my profile - up by Zion NP in Utah ...name is Steve (or Stephen when I am in trouble with the one "who must be obeyed". This car is in final paint and being reassembled which means I only have another 2 years to go ! So a story of sorts will unfold in the coming days to bring this blog to date. Then its onto project #2 a 57 coupe.
                    Hi Steve and welcome. It's good to see another 356 being saved.
                      Steve, Thanks so much for sharing this build with us! The story of your trials and tribulations while on the 356 learning curve ring true. I've made countless mistakes along my 25 year journey; for instance doing longitudinal repairs twice and a battery box floor repair three times before I finally figured it out. I'll continue to make more but you do at least figure out that its wrong a bit quicker. It was pleasure meeting up with you this week and I wish you the best of luck on your up coming A project. I'm happy to help if I can at any time.
                      Thanks again for posting your builds! Justin
                        Ok sorry... to many pics of that stage - anyway I ended up cleaning up the whole of the front nose area only to realize that with the metal patch work and pushed in headlight area I would be into serious bondo again to get it back ...
                        So ordered up a new nose from Trevor, now I was getting serious and way out of my depth ! Shown here cleaned and epoxy primed.
                        I took the old mounting plates of the old nose to weld on; so next mistake. The plates were too big for the new nose, or should I say the that area was not big enough for the plates. I choose to alter the plates and not the nose which of course is not a good idea.
                          Key issue is where to cut for the new nose, and new nose won't lay flat of the old one to give an accurate guide..so measure, then again measure and then measure again ! (and yepp I got it somewhat wrong Click image for larger version
                          trying to make sure I would cut equally:
                            Not having enough new metal to allow cutting past all the old sin is a tough spot to be in. Like the sight marker off the hinge mounts.
                              So eventually I just went for it.
                              There was impact damage and fiberglass
                              and rot (what else !) so the lip I tried to save came off too
