Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 1959 356A S/R coupe project chassis # 108625 - ABCGT Forum
  • Switching gears. The body is now ready to come off of the cellette bench so it can go back onto the rotisserie to finish out the remaining chassis repair details. Before it goes on now was the time to finish out the front and rear bumper fitments.
    Click image for larger version  Name:	IMG_2868.jpg Views:	25 Size:	241.4 KB ID:	116574 Wire wheeling the last of the filler and primer coats this front bumper came with. I would have left it but I found flash rust growing under the plastic filler that was applied directly to metal. This is why I always use an epoxy sealer base first. Bondo absorbs moisture and will wake up any trace amounts of rust if there isn't an epoxy barrier between the two.
    Click image for larger version  Name:	IMG_2869.jpg Views:	0 Size:	229.5 KB ID:	116579 Redoing a poorly repaired rust spot that formed under the deco. No repair patch, just flooded with weld and is very porous and brittle. You can get away with this approach on small holes but this one was way too big for that. I get the attitude behind this repair though, these small annoying chores never seem to end and it gets to point of " UGH! another damn hole; to hell with making a patch, just flood the damn thing closed". Its a temptation that can be hard to resist at times especially as the long journey of metal repairs gets towards its end.
    Click image for larger version  Name:	IMG_2870.jpg Views:	0 Size:	245.5 KB ID:	116580 Reamed the entire weld out with a step bit and now adding in a new patch.
    Click image for larger version  Name:	IMG_2874.jpg Views:	0 Size:	200.3 KB ID:	116581 Welds ground down, then picked and filed. All done here.
    Click image for larger version  Name:	IMG_2875.jpg Views:	0 Size:	205.0 KB ID:	116582 One more to fix on top where a license plate bracket may have been mounted at some point.
    • Front bumper continued:
      Click image for larger version  Name:	IMG_2876.jpg Views:	0 Size:	215.6 KB ID:	116584 Outer shell completely cleaned back to bare metal to ensure I got all the flash rust that was forming under the bondo. Now onto pecking out the obvious dents and lows spots that were left behind.
      Click image for larger version  Name:	IMG_2877.jpg Views:	0 Size:	239.6 KB ID:	116585 On the flip side a couple of the capture nuts needs some attention.
      Click image for larger version  Name:	IMG_2879.jpg Views:	0 Size:	234.0 KB ID:	116586 Then it was onto adjusting and fitting these new irons to this project.
      Click image for larger version  Name:	IMG_2880.jpg Views:	0 Size:	204.7 KB ID:	116587 I needed the bumper to able to slide over to the right a littler further. With both halves of the iron installed this eyelet was maxed out. I had three option to get around this: I could file the eyelet open further but there is not enough meat left on its end to allow that. The entire base mount could be removed and remounted over to the left a touch to center that capture nut in the eyelet or the last, easiest and least invasive option was to remove the capture nut face plate area and index it over.
      Click image for larger version  Name:	IMG_2881.jpg Views:	0 Size:	230.5 KB ID:	116588 This capture nut needed repair anyway so it was cut out. A new face and nut is ready to go back on here. It will be indexed over to center it in the eyelet for maximum adjustment options for the bumper.
      Thanks for looking.
      • Justin its always great to see the job being done properly as you have done with the rust hole. Its why restoration done well will always be expensive none of these repair jobs can be done in 5 minutes the hours soon clock up.
          Hey Roy, Thank you hope all is well with you! Yes, all these little repairs can side track things a bit but in the end it all has to be addressed eventually. Thanks! Justin
      • Finishing up the front bumper prep:
        Click image for larger version  Name:	IMG_2886.jpg Views:	0 Size:	224.1 KB ID:	116592 New capture nut tacked and indexed over where needed.
        Click image for larger version  Name:	IMG_2882.jpg Views:	0 Size:	193.3 KB ID:	116593 Now both sides are more centered in the eyelets allowing for any needed lateral adjustments with the front end.
        Click image for larger version  Name:	IMG_2889.jpg Views:	0 Size:	227.7 KB ID:	116594 Now onto cleaning the underside of the remaining old paint scale and rust.
        Click image for larger version  Name:	IMG_2891.jpg Views:	0 Size:	246.9 KB ID:	116595 A bit of work eventually got the entire underside clean along with the in and around areas of the mounts. While cleaning I noticed that one side of this blade was completely different color as the other half once I got past the top coat of primer. It became clear that this was two dead bumpers mated together to make one. No wonder the profile shapes were off side to side in the beginning.
        Click image for larger version  Name:	IMG_2885.jpg Views:	0 Size:	192.6 KB ID:	116596 One more full mock up with the car. Best adjusted position with a good consistent reveal all the way across. First test passed. Now for the second; adding in the jewelry for its final test fitment.
        Thanks for looking.
        • Finishing up the front bumper.
          Click image for larger version  Name:	IMG_2887.jpg Views:	0 Size:	249.6 KB ID:	116612 Trying out this HD industrial epoxy sealer system I got from a buddy of mine. Its recommended for heavy equipment exposed to the elements. Once I confirmed that my tops coats where compatible with it we bought this system. The sealer is off white and the activator is the green stuff. Both are very high solids and mix very much like JB weld. Its direct to metal and can be brushed on or thinned for a spray gun. Mixed it will yield over two gallons. The entire underside of the body will be sealed out in this coating. Probably overkill for the life this car lead but added durability will be nice for peace of mind.
ID:	116613 Mixed a cup of it straight with no thinner and brushed a heavy coat of it on to fill in my lead divots and other obvious imperfections. Once it cured it was block sanded level and is ready here for another overall coat of it thinned for a spray out with my gun.
ID:	116614 Second coat of sealer was applied then followed up with these thin swatches of putty to catch the last of the rough imperfections.
ID:	116615 Putty was blocked then sealed again then a work coat of white enamel was applied. Still some rollers to take out but this was as far as I needed to chase it. The body shop can take it the rest of the way. Reassembled a with all the trim for one final mock up.
ID:	116616 Then one last test fit to the car itself just to make sure there was no surprises for the owner or the body shop.
          • Last mock up
ID:	116618 Click image for larger version
ID:	116619 Click image for larger version
ID:	116620 Click image for larger version
ID:	116621 Click image for larger version
ID:	116622 Now onto the rear bumpers' final fitment.
            Thanks for looking.
            • Begin rear bumper fitment
              Click image for larger version  Name:	IMG_2911.jpg Views:	0 Size:	184.4 KB ID:	116624 Original bumper (not to this car) and a new reproduction bumper iron set.
              Click image for larger version  Name:	IMG_2910.jpg Views:	0 Size:	189.2 KB ID:	116625 All the threads had to be chased first.
              Click image for larger version  Name:	IMG_2912.jpg Views:	0 Size:	181.3 KB ID:	116626 Initial mock up.
              Click image for larger version  Name:	IMG_2913.jpg Views:	0 Size:	166.6 KB ID:	116627 A bit of shaping and rebending before these fit to the bumper much less the car itself but its a starting point.
              Click image for larger version  Name:	IMG_2916.jpg Views:	0 Size:	175.2 KB ID:	116628 Turned the car around and dismounting my rotisserie rig to prep the car for its new rear bumper.
