  • Rear cross member rust repair:
    Click image for larger version  Name:	IMG_3383.jpg Views:	0 Size:	190.2 KB ID:	117163 We have some rust repair to address along the backwall/rear cross member flange. The original engine shelf was cut out before the car came to me and I can only assume it didn't fare much better than this flange directly above it.
    Click image for larger version  Name:	IMG_3386.jpg Views:	0 Size:	199.1 KB ID:	117164 The rot is localized to the right side of this run only. With the left side intact I was thinking I might get away with just gas welding these holes closed. Began wire wheeling this area to get a better idea of just how far gone it was.
    Click image for larger version  Name:	IMG_3388.jpg Views:	0 Size:	175.5 KB ID:	117165 It was looking like I might get away with that approach but looking at it from the back side of this flange it was becoming clear that it was a bit too advanced. You can see in this shot that the wrap around flange of the closing wall as also rusted through.
    Click image for larger version  Name:	IMG_3389.jpg Views:	0 Size:	222.8 KB ID:	117166 Too much heavy scale and advanced rot down in this joint to leave behind.
    Click image for larger version  Name:	IMG_3390.jpg Views:	0 Size:	184.0 KB ID:	117167 The light shining from the front side here shows more breaches above and around the bumper mount flange. To fix this properly the entire cross member would have to come out.
    • Begin rear cross member removal.
      Click image for larger version  Name:	IMG_3391.jpg Views:	0 Size:	180.4 KB ID:	117169 Once the cross member is cut out the integrity of the frame back here is going to be extremely compromised and since my rotisserie works off of the bumper mounts sagging, flexing and or bending is a serious concern when the body is rolled over to one side or the other. This won't be an issue with the car fully upright or upside down; only the lateral forces created with it tipped to one side. I've had this heavy section of angle iron with threaded ends around since I made it for use with my car back in the late 90's.
      Click image for larger version  Name:	IMG_3392.jpg Views:	7 Size:	231.6 KB ID:	117170 Mounts from the wiring conduit holes so no modifications required. Most of the cross member has been removed at this point and cut just ahead of the bumper mount gussets.
      Click image for larger version  Name:	IMG_3393.jpg Views:	7 Size:	208.3 KB ID:	117171
      No matter how you slice it this a very tight and tough area to get at with the tail skin on. Thankfully I can remove that angle iron with the car fully upright or up side down.
      Click image for larger version  Name:	IMG_3394.jpg Views:	7 Size:	217.8 KB ID:	117172 Begin by opening up this pinch flange to remove the remains of the cross-member flange. You can see there is two layers of metal down in here. The factory doubled the cross-member flange over on top of itself for added strength and ridgity. The new repro parts do not have this detail but it will be added.
      Click image for larger version  Name:	IMG_3395.jpg Views:	7 Size:	172.5 KB ID:	117173 The belly of this flange run just about free. Much to my great relief I found that most of those huge spot welds along the outside of this run had missed their mark and save for just a coupe of spot welds that did, the center of this old flange pretty much slipped right out. I'll take it where I can get it. A lot of heavy rust scale coming out as the removal progressed. This was the right way to go.
      • Flange clean up and beginning corner clean out.
        Click image for larger version  Name:	IMG_3399.jpg Views:	0 Size:	206.4 KB ID:	117175 Needed that angle iron out of my way to wrestle this the rest of the ay out.
        Click image for larger version  Name:	IMG_3401.jpg Views:	0 Size:	200.9 KB ID:	117176 All coming free with only what remains at the corners along the outer bumper mount gussets.
        Click image for larger version  Name:	IMG_3398.jpg Views:	3 Size:	205.2 KB ID:	117177
        The tricky part next. The corners remain intact so I'll have to unpeel this onion without damaging the outer bumper mount gussets and the frames side walls.
        Click image for larger version  Name:	IMG_3400.jpg Views:	3 Size:	182.9 KB ID:	117178 Cleaning up the triangular gusset first. Two layers here with lots of spot welds. The flange remains of the engine shelf and the crossmember itself. No clear shot at drilling all of those out so this will be grinding and peel time taking care not to damage the gusset, upper closing wall and the frame sides as I go. Confined space with tucked in corners...lots of fun ahead.
        Click image for larger version  Name:	IMG_3403.jpg Views:	0 Size:	200.8 KB ID:	117179 One layer gone and grinding the final layer here. Prying it up and testing what I can rip away as it goes.
        • New cross member prep:
          Click image for larger version  Name:	IMG_3402.jpg Views:	0 Size:	189.2 KB ID:	117181 Getting the inside of that gusset cleaned of old crossmember bit by bit. This cleanout was extremely tedious so I had to take breaks from it.
          Click image for larger version  Name:	IMG_3387.jpg Views:	0 Size:	198.0 KB ID:	117182 In between the long grinding sessions in those corners of the frame I needed a break and began prepping the new crossmember for installation.
ID:	117183 This car is so late that the factory finally ran out of crossmembers with these pre- punched elongated holes for the 1956-57 removable engine shelf. Even though they hadn't been utilized for a couple of years the earlier 59's still had these holes lurking under their welded in engine shelves.
          Back filled for a correct late '59 appearance.
ID:	117185 Welds dressed smooth. Double folded upper flange detail replicated for appearance and increased strength and rigidity. Like most frame components this new part is made from 20 gauge whare the original was 18 gauge. Not the end of the world back here as its not critically load bearing as the technical end the chassis is at the trans hoop mount but I'm glad to muscle it up were I can.
          • justin more and more and more do I realize just how lucky I am not to have to face some if these jobs that come up to face you. Back in about 1975 I remember stripping all those parts and preparing them for paint and rust prevention. I thought that was a lot of work !!!!!
              The '70s was an amazing time to be involved with these cars I'm certain Roy. Really good cars were still plentiful and quite affordable. You'd have to have been off your rocker to try and save a car as rusty as this one back in those days. This car would have been stripped of its parts decapitated for the S/R clip and the rest sent to the shredder. No one in their right mind would have wasted their time and energy on this car back then as you all were so spoiled for choice. I'm glad you decided to save yours though. Justin
          • Back to corner cleaning:
            Click image for larger version  Name:	IMG_3419.jpg Views:	3 Size:	216.3 KB ID:	117189 Right gusset cleaned of old cross member. Just have to fish out the remains of its flange in the pinch seam.
            Click image for larger version  Name:	IMG_3406.jpg Views:	3 Size:	249.4 KB ID:	117190 Before I did that I wanted to catch the left side up as I wanted this unpleasantry behind me as soon as I could.
            Click image for larger version  Name:	IMG_3407.jpg Views:	3 Size:	224.7 KB ID:	117191 Same process of grinding and peeling while trying not to damage it and the surrounding walls as I went.
            Click image for larger version  Name:	IMG_3408.jpg Views:	4 Size:	232.7 KB ID:	117192 Left side gusset cleaned and in process here of removing the old flange.
            Click image for larger version  Name:	IMG_3409.jpg Views:	4 Size:	234.3 KB ID:	117193 Bending the gusset inward got it out of my way to get at that last bit of flange all the down to its corner were its fused closed with a gas weld.
            • The rust just lurks everywhere. You are into some tight hard to get at places that often require twisting ourselves into pretzels to get at them. Interesting in your pictures the two gussets on the rear inner wall. I couldn’t figure out what they are for and they are not symmetrical - with one on drivers side and not on the passenger side. Turns out they were built for holding the heater that in 1961 moved to the front. I’m going for a cleaner look in the engine bay so we cut them out and sure enough rot rust behind 😳
                It never seems to end Scott. Yes, those are the optional gas heater mounts. You're really going highly detailed in the engine compartment I see. I understand you shaving those for cleaner look.
            • So true Scott you have to be really fit and agile to get into these places to work on them. And yes Justin my 1959 car cost me £440- in the late 1960's and was in good original condition but not perfect. I had looked at several other 356A's before I bought mine in the £200- region but the old rust had got to them so so I paid more. Here in the UK so many of the early A's had rusted away.
              in 15 years !
              Keep working away at it.
                Wow! You sure could get a good car for a reasonable price for sure. Will do..Thanks.
            • Flange clean up continued.
              Click image for larger version  Name:	IMG_3413.jpg Views:	0 Size:	234.4 KB ID:	117205 Finally touched bottom in this left corner. Gusset and pinch seam cleaned of the last remains of the old cross-member. Still have to clean off that strip of metal down the sides of the frame which was the old mounting flange. That a bit later.
              Click image for larger version  Name:	IMG_3423.jpg Views:	3 Size:	193.8 KB ID:	117206 Moving over to the right side of the pinch seam. It became clear that this side did not fare well and was too thin and compromised to salvage.
              Click image for larger version  Name:	IMG_3424.jpg Views:	3 Size:	188.4 KB ID:	117207
              Decided to replace the entire right side of it. Didn't replace more than I had to though and made my break line right whare the severe rot ended.
              Click image for larger version  Name:	IMG_3427.jpg Views:	3 Size:	231.0 KB ID:	117208 It was the right decision. As I was attempting to get the rest of the old cross member flange free in the corner the pinch seam was coming apart all around it as I worked the area.
ID:	117209 Going to recycle more of this car's old original metal to make the replacement pinch flange from.
              • Justin I am amazed at what you have just attempted. I am surprised there are so few comments about just what you have undertaken here Justin. I suppose? the number of people looking on at all this work you have done on this care cannot comprehend how they could ever do it themselves so they just watch like me and wonder ! I wonder how many other hidden surprises there are?
                Keep smiling !
                  Thank you Roy! I always enjoy reading your thoughtful comments. I think for most, these posts are too detailed and the eyes just glaze over to ever care about commenting. I have a tandem post of this build going on the Registry and while its an active forum with a lot of views it gets very little feedback. But that is perfectly fine as these entries are intended to document what went into this car and what is really going on structurally underneath its eventual paint, upholstery and undercoating. This chassis will be known commodity so the next custodian can buy with confidence. Thanks again! justin
              • Flange repair continued:
                Click image for larger version  Name:	IMG_3441.jpg Views:	0 Size:	266.4 KB ID:	117213 Replacement section folded over into a new pinch flange. Since I'm only replacing half of it I didnt want it to look too fresh continuing on from the section that is staying. The factory used these enormous spot welds along the entire run. I wanted to mimic this detail as close as I could so I turned my hole puncher die over to the shouldered blunt end which produced this detent at just about the right size. This is just cosmetic to season its appearance a bit as this run will ultimately be secured with plug welds.
                Click image for larger version  Name:	IMG_3442.jpg Views:	3 Size:	233.9 KB ID:	117214 New crossmember and replacement flange section just about ready to finally go in.
                Click image for larger version  Name:	IMG_3443.jpg Views:	3 Size:	217.5 KB ID:	117215 X's are marked for the apron strut and the over rider tube mount placement.
                Click image for larger version  Name:	IMG_3445.jpg Views:	3 Size:	193.5 KB ID:	117216 Begin fitting the new flange section and final trimming at the outer corner.
                Click image for larger version  Name:	IMG_3446.jpg Views:	3 Size:	254.6 KB ID:	117217 Harvesting the tube mount as this and the apron strut have to be welded on first as there is no access to weld them once the flange is mounted.
                • Transplanting the brackets:
                  Click image for larger version  Name:	IMG_3447.jpg Views:	0 Size:	216.9 KB ID:	117225 No way to get a clear shot at welding this bracket on with the flange installed so now was the time.
                  Click image for larger version  Name:	IMG_3458.jpg Views:	6 Size:	182.4 KB ID:	117226 The apron bracket had to go on first as well. Dialing in its lateral position in relation to the strut bracket here. The apron brace is back into its original position with the strut tube mount centered with the hole in the body.
                  Click image for larger version  Name:	IMG_3459.jpg Views:	6 Size:	246.1 KB ID:	117227 All welded with a seam weld as attached originally. Just a little more clean up prep and this new repair section can go in.
                  Click image for larger version  Name:	IMG_3429.jpg Views:	5 Size:	224.5 KB ID:	117228 Switching gears for a second to clean the lateral walls of the flange remains of the shelf.
ID:	117229 A lot spot welds. Drilling carefully so I didn't go through the lateral panels to keep the outside surface looking as undisturbed as possible.
                  • Click image for larger version  Name:	IMG_3437.jpg Views:	0 Size:	247.4 KB ID:	117251 Finally past all those spot welds. Glad to have the footprint of the old tray here as a guide to installing the new one. As you can see it runs at a slight upward angle.
                    Click image for larger version  Name:	IMG_3438.jpg Views:	0 Size:	235.0 KB ID:	117252 Repeat left side.
                    Click image for larger version  Name:	IMG_3461.jpg Views:	0 Size:	188.2 KB ID:	117253 Moved onto installing the new replacement right hand flange section. All tacked in now and onto fully stitching it in next.
                    Click image for larger version  Name:	IMG_3466.jpg Views:	0 Size:	203.6 KB ID:	117254 All stitched and dressed right up to the corner.
                    Click image for larger version  Name:	IMG_3468.jpg Views:	0 Size:	191.0 KB ID:	117255 New lower cross member just about ready to go in but before I could do that I had to repair these additional rusted out areas along the sides.
                    • Well done Justin its going to look really nice. As I have said more than once before, its no wonder to repair body work properly on a 356 its so demanding on ones ' pocket ' if you cannot do the work yourself !! I have my oxy/acetelene brass welding torch in my garage that I have polished so bright just to remind me, of the hundreds of hours I took doing mine, so that I would never forget!!
                      Trouble is after 50 years of not really using that torch so much on my car,I have forgotten now, in my eighties how I actually did it all !!
                        Thanks once again Roy, I know you've been through this type of work before so you know exactly what your looking at. Yes, its easy to forget or lose the touch if you don't practice a thing regularly. I go through it when I pick up the torch to apply lead solder. I takes a little while to regain the ability to apply it successfully if I haven't done it for a while so I know what you mean. Justin
                    • Begin fitting the new cross-member.
                      Click image for larger version  Name:	IMG_3469.jpg Views:	3 Size:	226.6 KB ID:	117260 With the new flange fully installed and dressed I could finally begin fitting the new cross-member. Of course it begins a touch too wide as this was as far as it would go on the first try. Bottom leading edge of the cross-member gets a simple folding over in the corners to seat into the side wall flanges.
                      Click image for larger version  Name:	IMG_3471.jpg Views:	3 Size:	188.3 KB ID:	117261 It took a series of repeated test fits and fine trimming as it began slipping in closer and closer between the side walls before finally seating squarely and tightly against the corners.
                      Click image for larger version  Name:	IMG_3473.jpg Views:	3 Size:	219.9 KB ID:	117262 Corner gusset foot print traced to so I could drill for the plug weld holes.
                      Click image for larger version  Name:	IMG_3474.jpg Views:	3 Size:	209.2 KB ID:	117263 Dismounted one more time to drill the holes as well as other last minute prep before it goes back in for good.
                      Click image for larger version  Name:	IMG_3475.jpg Views:	3 Size:	215.3 KB ID:	117264 New Cross-member back in for the last time. Before I began welding, I dug out the new engine shelf to both test for square and clearance. I try to never make the mistake of just assuming the next part is just going to drop into place...because it never does. Fitment here was close enough to comfortably proceed. Welding the cross member next.
