  • Click image for larger version  Name:	IMG_3204.jpg Views:	0 Size:	214.4 KB ID:	116958 Direct comparison with the stock unmodified bumper. Again, everything from the exhaust ports inward remains original.
    Click image for larger version  Name:	IMG_3206.jpg Views:	0 Size:	174.6 KB ID:	116959 but outward at the corners its an inch shorter with a much tighter radius to match that narrowerT5 tail the car was fitted with. Outer overrider mounting hole really highlights the change.
    Click image for larger version  Name:	IMG_3208.jpg Views:	0 Size:	230.9 KB ID:	116960 Onto reinstalling the bumper bracket mounts themselves so I can get it properly mounted and adjusted to the car. The best feature about making the alteration cut at the exhaust port is that once this bumper bracket mount is all welded in it will both conceal the weld joint as well as bridge and support this area.
    Click image for larger version  Name:	IMG_3214.jpg Views:	0 Size:	181.9 KB ID:	116961 A very rough and preliminary fit with the new bumper irons. Couldn't get all the bolts in either but it was just a starting point.
    Click image for larger version  Name:	IMG_3216.jpg Views:	0 Size:	179.5 KB ID:	116962 Really happy with the reveal the bumper is creating with its new contoured shape against the tail but its ending up tight at the corners. That will require a bit more rework but the mission at the moment is just to get the bumper fully mounted.
    • Justin by the time this is finished you will deserve to be called the bumper expert !
      Well done
        Well, I wouldn't go as far as to say expert but I did learn a lot from this little side project. Thanks again Roy, its always greatly appreciated! Justin
    • Bumper iron shaping then reshaping again....
      Click image for larger version  Name:	IMG_3222.jpg Views:	3 Size:	170.0 KB ID:	116966 Basically starting from scratch as these are new irons with a modified rear bumper. Began dialing in and shaping the inner halves of the brackets as jumping off point. Much easier to establish this baseline first rather than trying to take both sides on as a unit.
      Click image for larger version  Name:	IMG_3228.jpg Views:	3 Size:	223.3 KB ID:	116967 Heavy steel and very uncooperative cold. This was one of many, many rounds of heat then tweak; test fit and repeat as needed.
      Click image for larger version  Name:	IMG_3227.jpg Views:	3 Size:	208.2 KB ID:	116968 Before it was over I also had to bend the ends rotationally at the mounting surface to get the bumpers' final pitch corrected with it snuggly bolted down.
      Click image for larger version  Name:	IMG_3229.jpg Views:	3 Size:	199.6 KB ID:	116969 On the chassis side I wanted the eyelets on each half of this bracket to remain open and aligned with one another for maximum adjustment range. At the same time through all the bending and reshaping I had to have the eyelets on the bumper side mount as evenly as possible with one another for maximum lateral adjustment ability.
      Click image for larger version  Name:	IMG_3219.jpg Views:	3 Size:	217.2 KB ID:	116970 This is the final fit and alignment I was after. Bolts in the bumper sit evenly in the eyelets in relation to one another for max lateral adjustment options and at the same time the eyelets on the chassis side are aligned and opened fully. I had this fitment on both brackets only to find out that the approach angle on one side was off with the chassis. As I bent the end into alignment the halves of the bracket would slide misaligning the eyelets I had worked so hard to keep open. This would require yet more heating and tweaking to iron out. It tried my patience on more than one occasion but I eventually got it all put to bed.
      • One more mock up
        Click image for larger version  Name:	IMG_3223.jpg Views:	0 Size:	206.4 KB ID:	116972 now fully mounted and adjusted on its new brackets.
        Click image for larger version  Name:	IMG_3224.jpg Views:	0 Size:	175.6 KB ID:	116973 Reveal shape and contour runs along the tail as closely as I could hope for but it turns too quick and tight at the tips.
        Click image for larger version  Name:	IMG_3225.jpg Views:	3 Size:	168.8 KB ID:	116974 Same problem on the left though just a little tighter still. Will have to relief cut the ends and relax these corners.
        Click image for larger version  Name:	IMG_3230.jpg Views:	3 Size:	199.8 KB ID:	116975 But I am at least finished with these bracket mounts.
        Click image for larger version  Name:	IMG_3231.jpg Views:	3 Size:	178.5 KB ID:	116976 To center the bumper with the body the eyelets are just about maxed out on both sides but it gave me enough to get by. I'll take what I can get.
        • Final bumper iron finish detail:
ID:	116978 The new irons are lazar cut with crips clean corners. The originals by contrast had a soft rounded leading edge.
ID:	116979 I took my die-grinder and removed most of the meat off of those sharp corners on both sides then file finished the runs.
ID:	116980 Two down two more to go.
ID:	116981 Shaped, filed and now finally finished. Ready for a top coat.
          • Justin that job has been done so well. Every time you look on the car and those irons you will remember the effort !
              Thank you Roy I appreciate it! I think you're right, as they did tormented me a bit.
          • Final finishing details:
            Click image for larger version  Name:	IMG_3247.jpg Views:	3 Size:	265.8 KB ID:	116985 Lead soldering across those weld joints and the rust repair patch area. Didn't take much but I wanted solder as the base filler.
            Click image for larger version  Name:	IMG_3244.jpg Views:	3 Size:	249.2 KB ID:	116986 Tight and uniform fit into the bumperette recess shape that I was after.
            Click image for larger version  Name:	IMG_3246.jpg Views:	3 Size:	229.9 KB ID:	116987 The old deco had some light deformity through the center that needed some ironing back out. Trickiest part was straightening it without bending or collapsing the shoulders on both sides. These stacked paint sticks in the center became the answer as I could both hit and clamp to them directly without damaging or bending the shoulders out of shape.
ID:	116988 Jogs and rollers now relaxed through the middle of deco with a close fitment to the bumper. Won't have to rely on the rubber base seal so heavily to back fill any shape discrepancies.
ID:	116989 Same fit through the weld joint areas. It was getting close.
            • Another mock up:
              Click image for larger version  Name:	IMG_3250.jpg Views:	0 Size:	217.5 KB ID:	116991 Fully reassembled once again to both recheck for fit and to confirm the changes needed at the corners. Took some effort to arrive here...
              Click image for larger version  Name:	IMG_3251.jpg Views:	0 Size:	215.5 KB ID:	116992 Once its all refinished there will be no detectable trace that this bumper was ever altered; even laying loose on the floor with the underside fully exposed.
              Click image for larger version  Name:	IMG_3253.jpg Views:	0 Size:	212.4 KB ID:	116993 Remounted and in its best adjusted position to the car.
ID:	116994 Last piece of the puzzle were the strut tubes. To get them in for this trial fit required the bumper to tilt backward a bit too far. Will have some changes to make these fit correctly but first...
ID:	116995 I need to get these tight corners relaxed.
              This up next..
              • Relieving the corners:
                Click image for larger version  Name:	IMG_3260.jpg Views:	0 Size:	164.9 KB ID:	116997 Bumper stripped back down then remounted in its best adjusted position against the body. Relief cuts added both top and bottom and now in the process of matching this final section to the shape of the body.
                Click image for larger version  Name:	IMG_3262.jpg Views:	3 Size:	186.5 KB ID:	116998 A second relief cut had to be added along the edge just above the overrider mounting hole to bring this area in for a smooth transitional line across this change.
                Click image for larger version  Name:	IMG_3263.jpg Views:	3 Size:	197.0 KB ID:	116999 A quick lap of metal tacked on to hold that shape while I dismounted the bumper for final backfilling and welding.
                Click image for larger version  Name:	IMG_3264.jpg Views:	3 Size:	204.6 KB ID:	117000 Beginning to stitch all of it back together. This change in shape has created a buckle through the center where it was not cut but this can be hammered upward into position once all the cuts are backfilled.
                Click image for larger version  Name:	IMG_3274.jpg Views:	3 Size:	183.8 KB ID:	117001 Welding complete and remounted for a test fit. That buckle through the center has also been worked out. All set on this side.
                • Justin its going to look great, so many needed alterations but they all tie in and clearances around the body look just like mine. What is interesting to me is the fact my car was ordered with the older style bumpers without holes in each chrome overider for the exhaust stubs and of course the rear chrome protection tubes. So I have no funnels for the exhaust tips.
                    Thanks again Roy! That is interesting, so your car was ordered new with a sport type muffler instead?
                • Click image for larger version  Name:	IMG_3261.jpg Views:	0 Size:	170.8 KB ID:	117005 Repeat the process on the right side.
                  Click image for larger version  Name:	IMG_3275.jpg Views:	0 Size:	174.8 KB ID:	117007 Same relief cuts as needed on the left side.
                  Click image for larger version  Name:	IMG_3276.jpg Views:	0 Size:	205.0 KB ID:	117006 Tacked with new contour established and ready to begin welding it back up.
ID:	117009 Welding completed on the right side. Remounted for another confirmation fit.
ID:	117008 Finally done cutting and welding on this poor old bumper.
                  • Justin I was told by the second owner of my car that the first owner was a young lady of only 21 years of age ( with a wealthy Father ) she disliked the chrome on the exhaust stubs going black with soot on her friends 59 356 so had it supplied with the sports exhaust and 400mm Speedster steering wheel. I have pictures of my car in the early 60's with the sports exhaust. I have nothing in writing other than that . She only kept the car for one year till she married. I still have the Speedster wheel she had supplied and have been pleased with it although it still seems large against my Ford Fiesta ! makes you think how good power steering is on the Ford though.
                    Bet you are pleased that bumper job is done !
                      Interesting bit of history with that car Roy. Its also so neat that you've kept all of these years. I hope at least one of your kids shares the same sentimental feeling about it and will treasure it when you're ready to finally let it go.
                  • Click image for larger version  Name:	IMG_3312.jpg Views:	0 Size:	237.1 KB ID:	117036 This bumper is now officially a 1959 356 "AT5" version. Its now not even close to fitting around the profile of a 356A tail.
                    Click image for larger version  Name:	IMG_3313.jpg Views:	0 Size:	226.0 KB ID:	117037
                    This is as close as it will get before the corners bottom out against the skin.
                    One more and final confirmation fit.
                    Click image for larger version  Name:	IMG_3286.jpg Views:	0 Size:	171.9 KB ID:	117038
                    Bumper dressed, fully mounted and adjusted to make sure it all fits and presents like it did before that last round of alterations.
                    Click image for larger version  Name:	IMG_3285.jpg Views:	0 Size:	176.8 KB ID:	117039Reveal shape and contour are good to go.
                    Click image for larger version  Name:	IMG_3284.jpg Views:	0 Size:	190.0 KB ID:	117040
                    Relaxing the corners have made the ends of tube fit even better. against the bumper. This raw fit will clean up perfectly once the paint and bodywork is completed.
                    • Click image for larger version  Name:	IMG_3287.jpg Views:	0 Size:	195.1 KB ID:	117041 Last piece of the puzzle. Fitting the strut tubes so they mount and exit out of those holes as close to center as possible with this bumper in its final adjusted position.
                      Click image for larger version  Name:	IMG_3288.jpg Views:	0 Size:	212.4 KB ID:	117042 Had to bend and tweak the mount tang as well as the end of this strut to get it to exit out at center of the hole.
                      Click image for larger version  Name:	IMG_3289.jpg Views:	0 Size:	173.7 KB ID:	117031 All synched down and centered in the hole. All done on this side.
                      Click image for larger version  Name:	IMG_3290.jpg Views:	0 Size:	201.5 KB ID:	117032 Right side by contrast was not as straight forward. It ended up mounting very high and over shooting the mounting tang.
                      Click image for larger version  Name:	IMG_3302.jpg Views:	0 Size:	215.1 KB ID:	117043
                      No amount of bending to the mounting tang was going to improve the fit. The end of the strut itself had to be relief cut and altered to suit.
                      • Click image for larger version  Name:	IMG_3303.jpg Views:	0 Size:	205.9 KB ID:	117045 Had to open that cut a little more as it went but it finally turned the trick. All synched down at both ends and exiting out at center of the hole.
                        Click image for larger version  Name:	IMG_3304.jpg Views:	0 Size:	191.5 KB ID:	117046 Ready for a tack weld to hold that position.
                        Click image for larger version  Name:	IMG_3306.jpg Views:	0 Size:	187.5 KB ID:	117048 Strut tube welded and set. Right side complete..
                        Click image for larger version  Name:	IMG_3305.jpg Views:	0 Size:	197.7 KB ID:	117047 and with these tubes mounted fully at center...
                        Click image for larger version  Name:	IMG_3307.jpg Views:	0 Size:	191.0 KB ID:	117049 The rear bumper conversion and fitment duties are finally complete. A very long, bumpy and winding road for sure but we finally arrived. Will break this down one more time to seal the surface in a base coat. Onto the next deal.
