Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 1959 356A S/R coupe project chassis # 108625 - ABCGT Forum
  • Conduit bender fab
    Click image for larger version  Name:	IMG_2764.jpg Views:	0 Size:	220.1 KB ID:	116364 Watched several videos on making your own tubing bender. Followed their lead and made my own shoe or profile die from a piece of pipe. Bent to a 90 that more closely matched my original reference examples.
    Click image for larger version  Name:	IMG_2765.jpg Views:	0 Size:	222.9 KB ID:	116365 Then it was onto build the base and fulcrum point. Other half of the pipe was used on the lever arm to pull and stretch the tube around the corner. All made from scrap and not pretty but it did the job.
    Click image for larger version  Name:	IMG_2766.jpg Views:	3 Size:	250.5 KB ID:	116366 The quicker and tighter 90 degree turn I was looking for.
    Click image for larger version  Name:	IMG_2767.jpg Views:	3 Size:	221.4 KB ID:	116367 Begin test fitments. A small silly detail but I was now feeling a lot better about moving forward with it.
    Click image for larger version  Name:	IMG_2768.jpg Views:	3 Size:	196.0 KB ID:	116368 Dialing the final stand-off length to match what was there originally.
    • Conduit tube in for good.
      Click image for larger version  Name:	IMG_2770.jpg Views:	0 Size:	205.7 KB ID:	116370 Last of the excess being cut clean and square with my trusty cutter.
      Click image for larger version  Name:	IMG_2771.jpg Views:	0 Size:	232.0 KB ID:	116371 Then flared the end as found originally. Tube now ready to go in for good.
      Click image for larger version  Name:	IMG_2774.jpg Views:	0 Size:	236.1 KB ID:	116372 Positioned to sit nearly square but with a slight upward angle to encourage any water that may find its way in there to drain into the battery box. Just making sure it doesn't pool and sit in the elbow. Both ends all welded up.
      Click image for larger version  Name:	IMG_8326.jpg Views:	0 Size:	465.6 KB ID:	116374 Every original undisturbed conduit I've seen received a two tack welds at the 3 and 9 o'clock position at the outer battery box wall.
      Click image for larger version  Name:	IMG_2775.jpg Views:	0 Size:	221.9 KB ID:	116373 Always shoot to replicate those original build details when possible.
      • Right fender brace installation complete.
        Click image for larger version  Name:	IMG_2773.jpg Views:	0 Size:	207.2 KB ID:	116378 Gas weld around the neck of the conduit sealing up the bucket. Leaving the plug welding around the headlight bucket for last in case there are any last minute adjustments that need to be made.
        Click image for larger version  Name:	IMG_2838.jpg Views:	0 Size:	231.9 KB ID:	116379 At the opposite end, the edges of the tube and flared hole in the box wall were fused around their edges as originally done.
        Click image for larger version  Name:	IMG_2772.jpg Views:	0 Size:	217.5 KB ID:	116380 Then it was onto the last two pieces of the puzzle. A full horn mock up would be needed to set and locate the base mount in its best position. The upper brace run was now a bit short with the new conduit. A small backfill extension in process of being added here. Dialing in the final needed length.
        Click image for larger version  Name:	IMG_2776.jpg Views:	3 Size:	209.4 KB ID:	116381 Upper brace lengthened and ready to go back on for good. Once this was tacked in the horn mock ups were next to set the base mount.
        Click image for larger version  Name:	IMG_2777.jpg Views:	3 Size:	211.7 KB ID:	116382 Right side fender brace completed. Horn mount set in its best position with gas welds replicated as my original reference shows. So much easier and cleaner to build this brace in the car to suit versus trying to wrestle a preassembled unit in to fit like it should. I missed a weld here BTW. The upper brace weld should be solid all the way around the conduit. I'll have to go back and weld up the center of it.
        • Click image for larger version  Name:	IMG_2778.jpg Views:	0 Size:	226.4 KB ID:	116390 Last confirmation fit after all the welding. Horn clears the bucket and battery box.
          Click image for larger version  Name:	IMG_2780.jpg Views:	0 Size:	184.2 KB ID:	116391 Horn sits level...
          Click image for larger version  Name:	IMG_2762.jpg Views:	0 Size:	196.6 KB ID:	116392 and is centered in the window.
          Click image for larger version  Name:	IMG_2781.jpg Views:	0 Size:	234.2 KB ID:	116393 Then it was onto one more confirmation fit for seal clearance with the ring before plug welding.
ID:	116394 Last little job on this side of the nose after the bucket plug welds was opening the holes for the turn signal.
