Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 1959 356A S/R coupe project chassis # 108625 - ABCGT Forum
  • Begin right fender repair:
    Click image for larger version  Name:	IMG_2210.jpg Views:	0 Size:	186.9 KB ID:	115440 Have to iron out some of that old accident damage towards the back of the fender before I can add on a new strip of 20 gauge. Only working out the obvious stuff at this point. Final planishing and shaping can't be done with the fender loose. It has to be mounted, welded up and set before I can go after the rest of it.
    Click image for larger version  Name:	IMG_2211.jpg Views:	6 Size:	202.6 KB ID:	115441 Begin with this bent wired edge.
    Click image for larger version  Name:	IMG_2212.jpg Views:	6 Size:	222.0 KB ID:	115442 After some heat and hammering, not perfect but close enough for the moment.
    Click image for larger version  Name:	IMG_2214.jpg Views:	6 Size:	198.9 KB ID:	115443 New strip of 20 gauge trimmed and ready to begin welding from the center outward.
    Click image for larger version  Name:	IMG_2215.jpg Views:	6 Size:	192.1 KB ID:	115444 Lower and flatter part of this run all welded up first. Trickiest part to come as the contour makes the upward turn. Old Reutter body badge holes saved by the way.
    • Click image for larger version  Name:	IMG_2217.jpg Views:	0 Size:	179.8 KB ID:	115462 Much trickier as it curves around. Have to keep watching the surface contour to make sure I don't tack it too tight or too loose. If its tight the patch will bow inward and if its too loose it will flare.
      Click image for larger version  Name:	IMG_2218.jpg Views:	0 Size:	169.9 KB ID:	115463 Upper portion tacked and on for a test to confirm that the patch surface carries on the general line of the fender.
      Click image for larger version  Name:	IMG_2220.jpg Views:	0 Size:	161.6 KB ID:	115464 So far so good but I missed that upper edge and came up short. Have to back fill it later.
      Click image for larger version  Name:	IMG_2219B.jpg Views:	0 Size:	196.2 KB ID:	115467My only concern at this point is this new strip matches and carries on the contour of the fender and is not tucking or flaring.
ID:	115468 Puzzle pieces fitting a little better each time.
