New splash pan repair section:
Onto metal. Basic shape with lateral and lower flanges installed.
Final placement of the new repair section is dependent on a tight fit against the inside of the rocker panel and whare it is positioning the rocker in relation to the edge of the door.
Bottom edge of the door has a bow that will need to be softened but this is my best average fit with a 3mm gap.
Dialed in close enough to commit to a final cut line. Ready to begin joining these two together.
Tacked and on for another test fit before I fully stitch these two together. Put a step in the lateral flange to accommodate the lap joint between the fender and the rocker so I could get this flange to butt up just a little closer.
Splash pan repair section complete:
Rocker mocked up one more time before I commit to fully stitching that new section on.
I've got my 3MM gap and the best average match to the edge of the door. The door has a slight bow to its profile and that will need to be softened but these adjustments are now minor corrections.
With the rocker in the sweet spot I simultaneously have the tight uniform fit against the back side of the rocker that I was shooting for. ready to stitch this up.
Lower stitching as well as the corner welding and lateral flange repairs complete. Excess to the inside lap joint trimmed and shaped to the original sweeping profile.
Another confirmation fit. All set and onto the next issue.
JustinLast edited by JTR70; 05-28-2024, 09:02 PM.Justin Rio
Right rocker skin rework:
With the rocker in its best matched and level position with the bottom edge of the door I am left with this gap with the threshold in its original position.
The deficit narrows slightly towards the back but I still well short the tight fit I need.
Forward drain pan also coming up well short of where I need this rocker skin to be.
Cut the back of the threshold free to allow it to move outward to help close up the shortfall. This wasn't really my answer as it creates misalignment with the striker post and the inner shoulder run would crowd the eventual base seal strip out from under the threshold ledge.
Didn't like the way that leading edge of the threshold flange was now peaking out from under the frames flange and it was still short up front.
Rocker rework:
My eventual answer would be to flatten and reposition the bend on the rocker skin side. I noticed there was a slight bit of excess at the upper edge of the flange run when fully seated against the threshold. I thought there might be enough there?? Beats the hell out of cutting and rewelding this long run...
Had to stop just in front the corner relief and will widen that separately.
I etched where the initial bend was and will rebend about 2mm behind this line.
The re-flattening stretched the metal and put a curve in the rockers profile. A couple bites with my shrinker jawsreversed that back out.
While I was on the subject of shrinking to preserve the rockers profile shape now was the time to take out this pair of drain reliefs. While they are a good evolutionary feature for drainage they are not correct for an A car. More rocker prep up next...
Right rocker skin work cont.
Seems simple enough just to pound this feature out flat again but I've learned it can't be done cold. The corners on either side of this relief have to be heated to gather and shrink up the stretched metal here. I tried hitting this feature out cold on an earlier project and the excess transferred both a bow in the profile and wave in the surface of the rocker skin.
Both unwanted drain features heated and pounded back out flat here and without distortion to the surface of the rocker.
Threshold flange re-bent .
Remaining corner highlights where it was.
Reinstalled for a test fit and this problem now solved. The leading edge of the flange also sits level with the threshold whare as before it sat too tall and needed to be trimmed back level.
Rocker skin prep cont.
Have some clean up work to go on this corner but will leave it loose until final installation time.
While the skins are loose, now was the time drill the rocker deco holes. Much nicer to install these flat on my table rather than vertically on the car. Using the original skin and an original deco to locate and drill the holes.
While I was at it the left side skin was done next. There is definitely an up and down side to the decos. If its flipped over the center holes will misalign slighty.
Holes centered and aligned to the originals.
Onto the next deal... Thanks for looking!
Justin now that was a full explanation indeed. A lot of thought to get it all in the position you are now in. Well done its very interesting to watch the procedure step by step. Also how useful some of your special shrinker tooling proved to be on this rocker work. You just cannot do this level of restoration without all these tools you have. You have a lot of confidence in yourself to attempt this work its not for the faint hearted at all!
- Likes 1
Back corner:
The right rocker is now in its final position and of course its wired lip is no where close to where it needs to be in both shape and position to seamlessly continue the wheel well arch opening.
Also have the corner relief shape to reposition and widen. The relief step for the lap joint is not crisp or tight enough.
Needed modifications begin. Corner cut free for widening and repositioning and wired edge cut and pried outward into basic alignment. Pounding that step out flat next and will install my own.
Remounted with a much tighter step for the lap joint requiring much less lead for final finishing. The wired edge is aligned but the shape on the rocker side still needs some work. Its too straight and needs a slight curve added to it before its joined together for good.
Plug weld holes drilled along the flange and set screwed against the threshold. So far so good.
Rocker all set for now.
One more confirmation fit. A good basic 3MM gap locked in.
Most importantly there is no severe overbite at the doors bottom edge. I have some contour correction yet to go on it but its all within striking distance at this point.
A relief seeing all this pieces fit together like they should with the door open and
this panel fitment across the gaps with the door closed. Gone as far as can with this rocker for now.
Back to prepping the splash pan for final installation. Acid cleaning the rust remaining rust here.
JustinLast edited by JTR70; 06-15-2024, 11:31 PM.Justin Rio
