Rotated the dowls and checked it from the front. Same result, I could not generate a rocking motion in the plate. The twin beams on this side are running as parallel in relation to one another as they can be.
Moved over to the left side. A slight rocking motion could be generated over here. Feeler gauge inserted into the discrepancy.
Thickest gauge I could get in there was 6 thousandths. Practically nothing...
My factory manual states max misalignment allowed is 31 thousandths... This beam is golden.
It was nice luxury to confirm this beams trueness with a factory checking tool but I'd have been shocked to find this assembly out of spec. If you've ever held this unit in your hands the first thing you'll notice is just what a heavy duty unit it actually is. The tubes and outer(also inner) flanges are really heavy gauge steel and if you're seeing my earlier pictures on the actual "frame" attachment points that surround it, it becomes apparent that the much thinner corrugated sheets really have a tiger by the tail. This beam assembly is the boss and the pressed frame sections will give way and deform long before it does. I do have a bent beam assembly floating around in my shop but the car it came out of had this beam shoved all the way back up and into the pedals. So they will bend but this car wasn't hit that hard. Onto pulling this beam assembly back out to factory specs.
Thanks for looking and my thanks once again to John Brooks!
