Hi
At the bottom are some metal strips welded. Maybe there are more on the replaced part?
A third part left and right?
And how much on the back?
There are holes in the back. Two with d: 30mm and one with d: 50mm.
At the end, are they closed with a rubber and what they are for?
There was a thin stripe welded outside. I think there is for grounding the rear lights. Unfortunately they did not replaced bevor mounting the outer panel. Where are they welded or is there a better solution for grounding the rear lights?
25 years build up with a lot of breaks. Unfortunately I do not remember me to all those detail!
Thank you very much for suggestions!
Happy New Year
Bruno
Happy New Year
Bruno
