356 The way it was...
    • too cool!
        • Hi, not sure how to private message through the forum. If you could send the high resolution copies to j.koning356@ gmail . com I would very much appreciate it!
          Thanks again,
          Joris
          • Look at the second engine, it has Weber 46 IDM carbs as used on the Spyders and 904's but is clearly a street configuration engine otherwise. Very hard to see but it look like the adopted the C2 air filters to work with the DCM's. Jacques and Gerry, have you guys ever seen something like this before.
            fascinating, gotta love these old factory pictures!
            • Also note safety wired cam cover nuts and 904 style exhaust valve covers. The weird thing is that it appears to be running a standard street exhaust system
              • That option is in now in the works along with a few other things John. I see Joris left his contact info. Let me know if you still need some help. Fantastic images as always!!!!
                Thanks once again!
                • Guys,
                  There is a way to get your large resolution pics on the abcgt website.
                  DOWNSIZE THEM!
                  There is a free program you can use: http://www.picresize.com/ .
                  Try it.
                  I usually shoot in VGA resolution so there is no problem or I have a Photosuite Program that I can downsize a large picture, if needed for sending on e-mail.
                  Anyway ROY in the UK set me up with this one, http://www.picresize.com/.
                  Try it!
                  I'm sure it will help.
                  • P.S.
                    I'll try to post a pic that I took of the Roadster with it s new Classic Lufteknic License Plate Frame.
                    First the one I shot in small VGA resolution then in a larger resolution for improved clarity that could be used on their website.
                    Not sure the large one will go1
