Dimension request
  • Dimension request
    Hello
    I'm replacing the batterybox at the moment.
    Only forgot to measure 2 dimensions
    Could someone here check the dimensions "A"(top) and "B"(bottom).
    (distance between suspension tubes and batterybox back wall)
    Thanks
    Bart
    Hi Bart,
    I'll try and get that bottom measurement for you today. Since the wall just has to run nice and vertical the top measurement won't matter much.
      Hi Justin
      Thanks! Really appreciate it.
      Looking forward to the dimension
      Grts
      Bart
        Hi Bart,
        I'm getting an average distance of about 12mm between the bottom tube and the wall.
        HTH.
          Hi Justin.
          Ok, thanks for the measurement.
          Grts
          Bart
            Use it as a baseline measurement Bart. I checked two cars and one was a little closer than the other at about 11MM's. I also found one corner to be tighter than other, side to side. Just shoot for your best average fit. Best of luck!
