I have been giving much thought into modifying a 1600 twin port beetle engine to replicate the feel and running characteristics of a 1600 Porsche engine. Obviously the Porsches internals are much lighter and there is some differences in the heads but I am sure they can be gotten around. The tin ware will be modified to look the part as well
My thoughts: lighter 8 doweled flywheel
counterweighted crankshaft
40mm x 35.5 valves
Port and polish job on the heads
8 to 1 compression ratio
40mm dual carburettors (weber IDF)
electronic ignition
Cam with about 276 degrees duration
Oil pump with filter
Fully balanced
Exhaust which mimics the original.
I am sure 80 hp is possible with this combination for a relatively inexpensive engine. To get to 95 hp maybe 1776 with 90.5 cylinders is the way to go.
Can anybody elaborate on these thoughts please?
Armand
40mm x 35.5 valves
electronic ignition
Fully balanced
Armand
