Guys especially Mic,
This is a continuing saga. After Mic's problem of starting ( not sure he solved it? ) I advised a while ago my earthing problem was improved by rectifying the soldered on washer on the battery box floor where the factory had only put 2 blobs of solder on it to captivate. The backside of the washer was rusty and dirty.
Anyway cranking was faster I could live with it until a week ago when the crank became really slow very suddenly.I double checked all earths and the battery. Now removed the starter and sort of suspect the solinoid coil connection with the copper strap to the starter casing. Looks like it has got hot.
I know I could drill out the 4 rivets of the end cap and possibly see really dirty copper contacts but as the armature or field windings or the connections inside might be suspect I have bitten the bullet and found a company that restores 6 volt 356 starters for the main 356 restorers over here.
He was fully aware of everything I mentioned to him, he will check each part and has done everything I thought of. Also he knew the old 356A solinoids are no longer available ( later versions are ).
I just could not face getting on my back again to put it back without knowing for sure the motor is in correct working order. If it didn't then work I know it must be the long 10mm core starter wire.
I think I can trust this guy he is doing many 356 starter rebuilds.
We will see. Not often am I defeated but in this case I am.
