*********** Lead wiping ***********
Again some of these repairs are out of sequence but I wanted to cover each individual aspect of the restoration from start to finish.
Before I get started here are the basic tools required that Jason either supplied or told me to buy. All the basic lead working stuff including the lead itself came from the Eastwood Co. The only item that did not was the solder paste which Jason supplied. Jason emailed me a list of tools&supplies he wanted on hand for his visit of which I had almost none of. Below is everything I'm using at the moment.
Here are all the basic tools & supplies that Jason told me to buy. The Dillon/Henrob Torch(now A.K.A. the Cobra torch) I bought as a kit on Ebay. (kit runs 300-400$) Solder paste (Jason) The rest is Eastwood: wooden paddle spreader set (16.00) Solder Tallow, the white stuff in the alloy tray. You warm this and coat the wooden spreader with it.(15.00) Body solder sticks 10pc. 1 LBS. (40.00) These sticks go quick! Pictured were my last two at the time.
This is the flux that Jason likes. Its an Australian product so I don't know if its available elsewhere. Whats nice about this paste is that it has solder mixed into it. So you apply it, heat it then wipe it with a rag leaving a nice primer surface of solder. The molten fill just loves it!
These are the body files that Jason brought for me. One course blade the other a bit finer and less aggressive. The plastic one is also adjustable to give the blade either a slight concave or convex surface. I really like this tool.
To get my feet wet I chose this small low spot at the bottom of the fender where I plug-welded the tang on. The welding made a slight low spot just like it did the first time it was installed. This area was done in lead by the factory too so its the perfect place to test and get aquainted with body solder. I followed the procedure that Jason had outlined and it all went surprisingly easy........
Surface was thoroughly cleaned. Applied the tining acid. heated it and wiped it over the area like I was shown.
Bulk of the solder applied and now ready to be reheated and spread out. Made a few mistakes. Most of which was getting it too hot and having some of it run-off onto the floor. Wasting it like that really pissed me off each time it happened but I learned and got a little better at it as time went by.
Solder now spread out over the low spot. This took me a while and several passes to get where I needed it. On the learning curve.
creating the rough shape with my body file.
Switched to emory paper to get the final shape.
Little bottom fill job complete. This was a great confidence builder for what was to become hours and hours of work ahead with it.
