Thank you Roy, that's very kind of you and I greatly appreciate your offer.
Bruce, I thank you very much for passing around the "donation tray" once again.
![Smile](https://forum.abcgt.com/core/images/smilies/smile.png)
12/14/15
Home stretch with the headliner
Debated about padding for the B-pillars as they were a lot smoother compared to the A-pillars but eventually decided to even them out.
Stopped it at the apex of the corner like the A-pillar before to reduce material thickness along the seal channel.
Left B-pillar wrapped. Glad I put the padding in.
On the home stretch as you can see with only the sail panel remaining.
Right A-pillar padded and recovered with B-pillar finished out as well. All that remains is that tricky little back corner.
A fun break was to fit my steering column and try out the looks of that old Nardi I bought a few years back. It was a fun diversion.(Bill Brown: Does this wheel look familiar to you; this is the early steel hub Craig Stevenson bought from you several years back. At least you're who he mentioned buying it from)
Back to work: I'm going to close the left side first so I glued in the second layer of padding in preparation.
Very loose mock up fit to begin rough trimming to make it more workable.
Generous cut line to leave me enough spare material while at the same time creating a manageable piece.
Relief cutting the windows as well.
Much better. Now I can begin stretching and planning my attack.
My mind is set on getting a wrinkle free end result. The best chance of developing a flaw is in this corner. The back panel and garnish rail play a part in that danger so I mocked it up here to get a better sense of where the clearances need to be to achieve the final product I'm after. More later...
