Canuck 1960B T5 Coupe Resto
T2A model but the set up is about the same.
Bracket faces the inner frame.
Not much height adjustment there so I'd recommend mocking it all up on the car to check for clearance with body opening to dial in your new bottoms best adjusted position .
Thanks Justin for your very helpful response and pictures. Good advice to check fit and the adjust.1960 356B T5 - under major resurrection.
- Likes 1
inner closing panels all done but not welded. This was a struggle to fit -- a lot of trimming and removing of material and then re-adding material. Also trimming to match door profile took some time. Still hesitating about welding in before I figure out the side fender piece1960 356B T5 - under major resurrection.
- Likes 1
- Likes 1
trying to reset the front body section. I think I have the hood latching smoothing but gets tight with body section installed. Can anyone send me a measurement for this height or other measurements of help to be sure latching mechanism is correct?1960 356B T5 - under major resurrection.
Thanks Justin
Need the members help on next steps. There are a lot of pieces here that all need to work together for the front and quite frankly I am not sure of the right order to tackle.
tasks:- splash pan/outer wheel well on either side are fitted but not welded (left and right)
- side front panel (between door and rear front fender) (left and right)
- nose clip
- top rain gutter (left and right)
The whole front piece is still removable and not fixed (only with screws) and the splash pans are all fitted and ready for welding – but not sure if now is the time to weld in the splash pan/outer wheel well just yet.
There seems to be three paths: one move from middle to front, 2 front to back and 3 rain gutters last
Option one
weld in splash pans
Fit up front side panel to front fender
install rain gutters
cut and replace nose
Option two
removal all and fit up new nose clip
work backwards by then installing the front section
replace rain gutters
replace side panel to front fender
Option Three
side panels
front nose
splash panels
rain gutter last
Thanks Justin
- nose clip
Option one
weld in splash pans
Option two
Option Three
side panels
front nose
splash panels
rain gutter last
Hoping members can reply above to the two questions: measurement for hood latch and order of next steps. I made up some wood forms to act as a guide for when I put the front nose on later.1960 356B T5 - under major resurrection.
Hey Scott, Didn't make it to the shop today but I'll get you that measurement for a baseline. However, it really doesn't matter what my car or anyone else's measures out here. The latch and all the surrounding panels both new old just have to work and align together in the end. As you know once you cut these cars apart things just change and the necessary adjustments have to be made regardless what it once measured out as. Take a look here at my journey resetting the front latch out in open space:
2/21/13 My new project arrived today by truck. (as if I didn't have enough to keep me busy ;) ) This is a side job I have taken on to both help a friend with a dream and to finance my on going projects. My friend is a surgeon here in town who I have trained for going on 10 years now. He's an avid car guy who up until recently had only a passing interest in old Porsches. I guess talking and hanging out with me all these years has rubbed off. :) He of course gravited to the speedster model. While he can afford just about any speedster he wanted, he got interested in a full conversion of a coupe giving him the ease of mind to really use and enjoy the car without the worry of sinking 250K+ in a real speedster. This car will be a full and proper conversion but will keep its original identity as coupe with its chassis#. Here are few photos from today. [ATTACH=JSON]{"data-attachmentid":12768}[/ATTACH] Donor chassis being uncrated. Took a while but we finally found a suitable platform. Ric at "Rusty Tubs" hooke
Its an A car but the procedure will be the same. As for your list you'll definitely want the splash pans fully set and welded in before any of the body mounts over it.Justin Rio
Question on Headlight buckets. Any preferred source for a supplier or recommended manufacturer?
I was supplied Buckets from Dansk on that Coupster project. They were really good and fit into the fender openings well. The original Hella headlamp units also slipped over the shoulder flange. The only thing I did not like was that the housings themselves where about a half inch shallower than an original. This wreaked a little havoc with the fender brace/headlight wiring conduit but I made it all work in the end.
