Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 65 SC Resurrection starting. - ABCGT Forum
  • #76
    John- great milestone achieved. Awesome attention to detail and work. Only as good as prep. Difference between a good paint job and one like this just takes it to a much higher level that just looks incredible. This looks like a wet seal in water.
    • #77
      Scott
      thanks you are right, starting to put it back together now, should be done before the first of the year . Glass back in, hood and door seals in, deck lid and hood back on. Straying to look like a 356 again.
ID:	116136 Click image for larger version
ID:	116138 Click image for larger version
      • #78
        Reassembling continues, doors on, jewelry begins, cleaning grounds, electrical connections, new rubber seals etc. It’s the little things now and attention to detail. After paint gaps are good, the body is razor straight.
        Click image for larger version  Name:	IMG_7363.jpg Views:	0 Size:	1.50 MB ID:	116145 Click image for larger version  Name:	IMG_1845.jpg Views:	0 Size:	836.8 KB ID:	116143
        Click image for larger version  Name:	IMG_7355.jpg Views:	0 Size:	1.82 MB ID:	116144 Click image for larger version  Name:	IMG_1844.jpg Views:	0 Size:	817.7 KB ID:	116141
        Click image for larger version  Name:	IMG_1847.jpg Views:	0 Size:	719.8 KB ID:	116142
        she will back on the road soon thanks for looking.
        Also Frank Swanson just sold his 64C today on BAT today, after 10 years of evenings and weekends, he just ran out of gas, on the project. Someone got a very well documented and well done project.
          Looking good John. I see you've done your first polish pass. I assume you'll chase out the haze once the paint fully hardens this spring? Oh, that your buddy's bare metal coupe on BaT. Keep up the great progress.
      • #79
        Today was electrical day, started installing the “Vintage Trader” LED conversation kit. Jules spent a little over a year researching the best LED replacement bulbs available. He makes a complete kit with all the replacements including head lights and killer instrument bulbs.
        I did a similar kit a few years ago, I used Chinese LEDs from EBay. I just searched the SAE base style and 6v LED. They are adequate , but only 40-50% brightness and quality of the Vintagetrader.com kits. Note the brightness of the small front parking bulbs, spectacular!
        Click image for larger version  Name:	IMG_7370.jpg Views:	24 Size:	1.40 MB ID:	116151 Click image for larger version  Name:	IMG_7369.jpg Views:	23 Size:	1.26 MB ID:	116150
ID:	116159 Click image for larger version
        Click image for larger version  Name:	IMG_7371.jpg Views:	20 Size:	1.56 MB ID:	116152
          An excellent product.
      • #80
        We’re getting close, did the factory water hose leakage test on the seals this afternoon, all is well and dry….
        Then drove it about 10 miles got the oil up to temp, rides well, handles as expected, stops straight. Looking good, now back to upholstery shop for a couple weeks
        Click image for larger version  Name:	IMG_1863.jpg Views:	0 Size:	682.6 KB ID:	116168 Click image for larger version  Name:	IMG_7417.jpg Views:	0 Size:	1.59 MB ID:	116169
        Click image for larger version  Name:	IMG_7418.jpg Views:	0 Size:	1.55 MB ID:	116170 Click image for larger version  Name:	IMG_7414.jpg Views:	0 Size:	1.61 MB ID:	116171
        thanks for following
          She looks great John.
      • #81
        Put the laser on the new led headlights, got them adjusted, you can see the red center line hight on the wall. Hood adornment is the last thing to go on, after cutting the paint. . Drove it to the local car club today and then off to the upholstery shop to install the interior. Ran fine, big hit with the locals, with fresh paint. Looks like a new car now. So it will be with the interior guy for a week or so, then back for a service and some more driving miles of shakedown. But she’s getting close to the end.
ID:	116174 Click image for larger version
ID:	116173 Click image for larger version
          Those LED's sure put out the light don't they. Already back on the road for cars and coffee?
      • #82
        The Car is still at the interior shop. He is slow but sure. Ted’s day job is working on airliner seats. He uses a SEM dye that can be matched to any color. It penetrates well and you can sit on a seat 2 minutes after applied. Alaska Airlines uses it on turnaround cleaning between flights. I must admit I have see age old Marhide dye seats, I was not impressed. This stuff is spectacular, the local auto body store can mix it to match and put it in an aerosol can.
ID:	116204 Click image for larger version
ID:	116206 Click image for larger version
        Replacing the old coconut tar insulation with Dynamat. It’s going in over top of the truck bead liner, we used seal up the inside of the floors after repair. All that’s left is I have to drive it 4-500 miles to shake out any bugs. Then a major tune up with oil change we are done. FINALLY..
          The owner has to be pleased with it. Great work and effort here John.
      • #83
        We’re getting close. A couple last minute things, like trunk trim, the amber turn signal lens, another tune, valve adjust, and a few hundred miles when it’s dry out.
        Click image for larger version  Name:	IMG_7538.jpg Views:	0 Size:	1.69 MB ID:	116217
        Click image for larger version  Name:	IMG_7535.jpg Views:	0 Size:	1.83 MB ID:	116216 Click image for larger version  Name:	IMG_7536.jpg Views:	0 Size:	1.86 MB ID:	116218
        Click image for larger version  Name:	IMG_7534.jpg Views:	0 Size:	1.88 MB ID:	116219
          The dye is just the right hue not too red with a little burnt orange tinge to it. Vintage Porsche look to it all the way.
      • #84
        Done……. All it needs now is a few hundred miles on the rings. Looks like new. Its idling here, no smoke, heater is on defrost on, everything works.
        Click image for larger version  Name:	IMG_7580.jpg Views:	19 Size:	1.48 MB ID:	116228 Click image for larger version  Name:	IMG_7574.jpg Views:	17 Size:	1.23 MB ID:	116229
          It looks fantastic John, both inside and out. Congratulations on a job very well done!
      • #85
        That dye is a SEM color coat. The local paint store (WESCO auto body supply), can color match it with an optical scanner like paint. Then put the dye in an aerosol spray can like paint. We took a seat bottom section that was folded under an had never seen light to match it. Once mixed you can apply it with a spray gun or the can. Its matched perfectly, and you can handle it in about two minutes. The dye penetrates the material, drys fast and is permanent . Our interior guy does airliner maintenance, he uses it all the time on leather seats. He did restitch the original and rebuild the springs and padding like the factory before the dye. After that its was just sprayed and put back together. It was a job, but worked out well to keep as much of the car original as possible. Remember this was a resurrection not a restoration. We are putting it back on the road as a solid rebuilt driver not a concourse trailer queen.
          SEM makes the best interior dye. I used that to go from gray to blue on my old Toyota and better than 30 years later it is still holding up!
