Hello, I have a T5 Roadster and I wanted to know the best strategy for finishing off the top of the front door seal. I believe the roadster has some unique curves and angles here vs. even a Cabriolet, so any pictures are much appreciated. Pictures of this exact area are hard to come by. I'm not super concerned if it's 100% original, just want to to be a satisfactory solution as I glue the new ones on.
In this random example I found of a restored car that was up for sale, it looks like the person just sort of made a messy slice-and-smash approach. I guess that could work. As I am lining up my seal, I see if you cut it short, you end up with incomplete coverage and you could see body-colored metal at the top. If you make it stick up long, you end up having to smash (like the pic below) or something. I was considering making some fine razor blade cuts as I approach the top of the door and glueing the resulting pieces down as I go. (remove pie-wedge pieces basically to allow it to "fold and collapse" onto the door metal at the top). (click for huge version)
Here's another random pic I found. It's also not shot from a great angle, but it looks like the front seal sticks up like a mohawk. But looking at my door, that would seem to make a scoop that would funnel water inside the door - worse than having no seal at all maybe? Plus, I can't imagine this looks great when viewed from the top or outside of the car. (click to make it bigger)
Here's another found on Autos Intl's site. This is a work in progress so this may not be the final shape, but it looks like they're doing sort of a bend-and-smash with glue type approach
Some pictures would be awesome if you have any. I'm just looking for a "nice" install - doesn't have to necessarily be concourse-judge-approved haha.
Maybe this falls under the category of "if it looks good to you, then it's good"?
Thanks so much for any pictures you can attach!
Brian
Brian
