Now its been a long time since I tried to place photos on here. Last year I had an original rear wheel bearing cage break up and then loose oil. This job meant replacing in the end the bearing the oil seal, the distance pieces the seal rests on, the "O" ring and the back distance piece as well. This job was actually quite involved and it has to be done correctly. I took some photos of an extractor I made to pull the wheel bearing out. Tried to find the VW special tool to do this job with no luck and tried all my extractors and several of my friends one all to no avail.
So below is a photo of the extractor I made that was cheap and worked so well !!
Ah Ah that did not work!! So I have to look into the process of how to post pics. Normally I use the IMG method after first resizing the picture to the required size. I will be trying again!!! Ah Ah !! just scrolled down the page to see ' select from Photo album ' and 'upload ' Never noticed before so here goes!
Photo of extractor and dimensioned drawing
Got this photo up how do I make it bigger please advise.
