Hello all
So I've been slowly reading up about the differences between s75, s90 and SC engines and want to get the full low down on them. I want to build a solid engine that will give plenty of trouble free mileage but also one that can take a bit of hammer, although I won't be going racing with it so no revs over 6k. I have a 95% complete s75 engine but don't think many parts will be right for this build.
I'm gathering bits together to build an engine but want to know what the most cost effective/durable solution is for a good engine. I have a s90 case and want to build it up around that. Is it best to go for a SC (or stoddard/scat) crank counter weighted. Barrels and Pistons I will likely get new larger to take it up to 1750cc(or what ever the exact cc is). And heads, I have a set of s75 but will want a set of s90 or SC/912 heads. Carbs will be straight shaft 40's? I read there's a difference between s90/sc by a casting on top of the carb somewhere maybe a breather? What else is recommended, it seems that most s90 parts will have been well used and cracks on the crank/heads will be my biggest problem.
I'm relatively new to the 356 world so any information will be greatly received!
Thanks
Thanks
