distributor
  • distributor
    i've found a little time to play with the 356A. I have two distributors
    1ea. of no.- VJR 4 BR 25
    1ea. of no.- 0231129002 JFR4
    I believe the VJR is the one that was in the engine,58 1600N
    so what one should I use? is one better than the other? the engine has a big bore kit 912 cam and ether 40mm dell's or webers
    Mr.Badsix:
    I believe that both are from a VW engine.
    I've forgotten the correct series no. for your engine, but you can't go wrong with an 022 from the later cars.
    However, if authenticity is an issue, I suggest you engage Mr.Glenn Ring, who has been on this site, but is most likely to be reached on The Samba. He is quite knowledgeable about these things.
    Good luck.
    Keep 'em flying...
    S.J.Szabo
      thanks SJ i'm going to try and get in touch with Glen
        Another good contact is Bruce Smith. His website has come good information
        http://www.sparkingplugs.com/4.html
          sorry on my fist post the one distributor is a 0231129022. that's good
            D'oh! Amazing the difference one digit makes!
              thanks Jack
                I've been there many times myself! Usually with phone numbers
