tunnel hard fuel line
  • tunnel hard fuel line
    restoring 62 356
    what size( diameter) is the 1700mm steel tunnel fuel line and what can i use to replace it.. steel, SS?
    thx
    Lester
    p.s.
    submitted picture for profile dont know why doesnt appear
    Hi Lester,
    Thanks for joining us and Welcome!! As to your fuel line question though not original I might recommend using copper tubing for that run. With todays fuels there is more moisture content in them causing regular steel lines which that originally was to rust corrode a lot quicker. S.S. might be alright though its much tougher to work with. Hopefully Jack, or Bruce might chime in here an expert opinion. Thanks again, if you get a chance please tell us about yourself and your project in the welcome mat section.
    Problems Loading photos: The file size might be too big or if your using Firefox as web browser this would also cause the problem. This site is not compatible with that version for photo attachment loading. Use IE8, Safari, google chrome.
      thanks for advice on using copper/SS.
      However there is a decent supply of ethanol free fuels in the Atlanta area
        The factory size is 8mm, but 5/16 works just as well and is more common here in the states. Never have had much trouble with steel on running cars, only ones that had the fuel system open and out in the elements.
        PS: Name, please?
          Where do I find 5/16 tubing x 170cm?
          Thx
          Lester
            Iooks like Grainger sells 5/16 x 6ft SS tubing.
            I'll try them.
            Thx
            Lester
            ATL
              Lester, after two days of shaping and working with small SS lines I've learned and changed my mind it is pretty manageable to work with and I'll now be putting in a SS fuel hardline in my car. Glad you found a supplier.
