Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Warning: Undefined array key "p" in /home/justin365/public_html/includes/vb5/template.php(404) : eval()'d code on line 794 Spyder 550 550A - ABCGT Forum
    www.breuer.shop
    • That is Hans Stuck in 550-03 (#140) at Freiburg-Schauinsland Int Hill Climb Record
      • #101 is 550-0040 driven by Rodriguez
        • Thanks Andrew
          But which year : 1953 or 1954 ?
          The European Hill climb championship who include several reknown hill climbs such as Freiburg Schauinsland,
          Gaisberg, Mont Ventoux and many nothers onlyn started in 1957
          • #98 - 550A-0131
            #100 - 550-0036
            #101 - 550-0040
            #102 -
            #104 - 550A-0125
            #105 - 550A-0141
            #107 - 550A-0143
            #108 - 550A-0137
            #109 -
            #110 -
            #111 -
            #112 - 718-005
            #114 - 718-003
            #115 - 717-00?
            Not sure which spyder is #102 - 550A indicator lights on the front but is a 550
            • #140 - 1953
              • Originally posted by Porschinelle" post=42552
                Hi Michael
                2 pics showing the 2 Carrera's at the same corner
                Obviously large differences between the 2 cars
                Sepp Greger car looks older (behive lights + 6 louvers instead of 5 on HvH car)
                HvH registration Stuttgart
                Sepp Greger ?
                • Originally posted by Porschinelle" post=42553
                  A front view of the 2 cars
                  HVH first
                  Sepp
                  Anyway although he had an older car Sepp did far better than HVH
                  • Looks like the factory in the background.
                    • Hi Vance
                      I believe you are right for the factory in the back
                      I also believe the driver to be Max Nathan
                      May be the same car same day
                      The 5 is behind Max
                      • Max Nathan with that same car at the 1956 S
                        • Max Nathan with that same car (550-045) at the Solitude GP 1956
                          Andrew your opinion please ?
                          • Yes, Max Nathan with 550-0045 #25 before the 1956 Avus GP
                            • Thanks Andrew
                              Max Nathan was German
                              Do you know why his 550 is not wearing a German registration ?
                              By the way from which country (Austria ? Sweden ?) is the registration A 85200 ?
                              • Max only piloted some of the races. The car was owned and also raced by Swedish driver Gert Kaiser, which is why it wore the Blue and yellow livery
