I'm assembling my engine to figure my dome volume and to check for valve clearance. during assembly I put the crank in the case it spins free with very little drag. then I installed the cam with the timing marks correct. now the crank is tight, It turns but has quite a drag on it. the problem is with the crank up against the thrust at the flywheel bearing it turns hard. if it move the crank to the pulley end it turns free and the gears line up perfect. when its back on the thrust the gears are off about 1.12mm. cam and crank gears are new, cam is new and has no end play. crank is std. case is std. crank bearings are std. what's wrong ?
Jay D.
Jay D.
i'm surprised that you can't put insert bearings in these cases like they use to do vw 36 and 40 hp cases maybe bearings are the problem.
Never mind. I don't understand your methods.
